Efi speed sensor ?
Old Feb 22, 2010 | 07:33 PM
rs milesy's Avatar
rs milesy
Default Efi speed sensor ?
Need to get a speed sensor for my S1 EFi conversion,I am using FRST OFAB ecu, loom etc, Question is can I use a speed sensor from an XR2i or a mk4 efi xr3i or does it need to be the FRST speed sensor ? and does it fit the S1 gearbox ?
Thanks
Old Feb 23, 2010 | 06:41 PM
So long as it fits the box will be fine, doesn't matter where it comes from, it merely senses and gives a square wave signal, if it fits a crank sensor etc can be used.
Old Feb 24, 2010 | 12:18 PM
rs milesy's Avatar
rs milesy
Thanks tabetha,
It is the last part of the conversion I need to sort out, I have the crank sensor fitted to the block and the efi flywheel, Do I still need the speed sensor ?
Old Feb 24, 2010 | 02:20 PM
I don't know with your ecu, but if it uses one it will need to have one on the install.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
fordrallycar
Sep 30, 2015 07:57 PM
