cosworth turbo
Old Feb 21, 2010 | 08:53 PM
efiturbocab's Avatar
efiturbocab
Question cosworth turbo
how easy is it to change the set up of a t3 from coswort to rs turbo
Old Feb 21, 2010 | 09:00 PM
10th_racer's Avatar
10th_racer
you need a new downpipe to bolt straight onto the exhaust housing, heres a crap picture of mine
Old Feb 21, 2010 | 10:46 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
do you mean you want to fit a t3 from a cosworth to an rs turbo?
if so then you have a few routes to go down.
you can just unboltthe core and attatch it to the escort rs turbo turbo exhaust housing, this will boost more, but will still have the limitation of the 0.36 housing, but you can get a 0.48 housing and retain near the cossie housing potential.
alternatively you can do as pictured above with the complete cosworth turbo unit fitted to the escort rs manifold, just a modified cossie downpipe would be needed.
i did the latter for mine as it flows better than the rs turbo elbow off the turbo unit.
Old Feb 21, 2010 | 11:08 PM
mattyboyrst's Avatar
mattyboyrst
i have a stage 3 turbo 48ar housing and 60 trim compressor wheel is this the cosworth turbo got told its the same size compressor wheel
Old Feb 22, 2010 | 09:55 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
yes it is, it's a cosworth sized compressor wheel and housing etc.
basically it's a T3 with a compressor wheel of exducer 60mm and trim of 60, that's what was used on a 4wd cosworth and all the t3 turbines were the same.
a stage3 t3 is basically a 4wd cossie turbo, but has a 360 degree bearing to spread the load of thrusting better.
big_Rad
Sep 15, 2017 09:36 AM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Matt Baxter
Sep 16, 2015 08:30 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Aug 14, 2015 07:29 AM
