EFI Head, Adapter plate or head work?
Just wondering it the standard mfi head can have the injector cut out ground into it? or does it hit a water gallery or something?
Failing that does any one have an efi head they want to sell?
Or
Any one know where i can get an efi adapter plate, other than ferriday engineering £107 bloody quid!
Rob,
Or
Rob,
Or
Rob,
Or
Rob,
got mine off ebay mate. came with the longer studs and nuts. Think i payed 30 quid. It matched up to my ported head great. Cant find the seller for you as it was over 90 days ago and ebay wont let me go back..GRRRR.....
either way will work pal.
you can open the ports for injector cut outs, remember MK's mk2 fiesta?
in blue properly modified track car, that had an mfi head with ports opened up to give injector cut outs, no issues there.
i run an adapter plate on mine as it was only £25 to my door, although i got longer studs from a supplier locally for a couple of quid.
Cheers lads,
Had a look on the bay for adapter plates but can't see any
but maybe im just being special.
Can't find any efi heads close enough urgg so i guess its grind the head, thanks xr2wishy for letting me know it can be done
Thanks again for the replys
Rob,
Rob,
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
