Fan loom for cosworth
anyone know where to buy new fan looms for cossies? cant find them on ebay anymore. need it bad :P heh.. If not, anyone know the colours of the 4 wires that goes in to the temp sensor on the rad. ?
I have a really bad loom in general, so the contact for the fan sensor isn't there :/
show me? =)
detailed... Need to hook up the right wires :P
and the temp gauge in the dash isn't working. does this have any effect on it?
I've just hooked up an aftermarked one. and a switch for the fans... hate the switch :P
https://passionford.com/forum/techni...ont-shoot.html
Try this i would use 2 fused relays instead of one there are plenty of posts about it try the technical section and in Motorsport devolpments have some good advice.
hmmm... okay. look at this one her... this is my fan switch:
is this a stand alone unit? or does it need signal from the ecu to work properly?
On one of the drawings "velocity" drew for a guy in here wondering about the same thing I cant see any ecu signals to the fan switch.
Temp sender for gauge is independent and has no effect on the fans at all it is screwed into exhaust side of head which is most likely guilty culprit can be confirmed by removing wire and earthing gauge should go to full indicating faulty sender.
That fan switch looks strange in that it has four pins it, you haven't changed to aftermarket management have you? Unless you have rewired it's more likely to be wiring than fan switch itself. Try bridging wires at fan switch if still no joy then will be power problem.
Martin
Martin
big_Rad
Sep 15, 2017 09:36 AM
muz
Aug 16, 2015 12:57 PM
Aug 14, 2015 07:29 AM
