Rouse Rear Spoiler Gaskets
Well after a nightmare job to remove my old standard spoiler due to the dreaded ferris oxide,
my bootlid had a fifty pence size hole beneath the centre pillar and the bolts that held the spoiler in place had to be chopped out
So after running around breakers yards to aqquire a replacement bootlid I had a brainstorm
whilst my replacement bootlid and Rouse rear spoiler were getting painted I thought of this little innovation, Rouse rear spoiler gaskets
to sit between the pillars of the spoiler and the surface of the bootlid
modelled from my own spoiler these are 4mm thick Rubber neoprane gaskets, should help combat stress fatigue on the spoiler preventing cracking as Rouse spoilers are made from fibre glass, can also seal against moisture to prevent bolts rusting in solid, also provides a bit of flexibilty between boodlid and spoiler
solid gaskets you will have drill you own holes when fitting
£10 posted to any member
check out pictures below, my own spoiler awaiting fitment, I shall be using these myself so I'll be a guinea pig also
Luciano
Luciano
155lee
Sep 6, 2016 11:10 AM
chris m1
Sep 7, 2015 08:02 PM
