G3 escort RWD
Car is now fully painted in ford diamond white.
spec at the moment as follows,
2.8 capri back axle
5 linked
watts linkage
watts cover
cozzi rear discs/calipers
capri 2.8 front disc/calipers
avo coilovers all round
adjustable tca,s
adjustable front struts
mk2 world cup cross member
mk2 quick rack
aluminum wide arched/sills
C20LET/ low comp/arp cometic/ h.beam rods/modified sump
now all ive got to do is wire the C20LET loom up to the rs loom, easy peazy
still a fair way to go yet, fuel pump, all ancillaries and some bling. have been trying to upload some photo from photo bucket but dosent reconise the Http adress, as soon as i get sorted i will upload some, there a few in my profile pictures for those who cant wait.
R25-28 converted gearbox to cable clutch
bias peddal box
GT35 turbo, not fitted yet
alloy petrol tank in boot
2.8 capri back axle
5 linked
watts linkage
watts cover
adjustable tca,s
mk2 quick rack
bias peddal box
When i purchased it, it had nothing but the shell, no running gear. the only thing that came with it was a world cup cross memember and a quick rack. i believe it ran a C20LET befor as the engine mounts were for this type of engine. i was told it was built by Denis Moody from Gartrac, dont know if this is right or not. but the fabrication is excellent, very very solid shell.
Looks very nice, prob ran a xe version originally more usable if it was rallied, if you need any info on the wiring pm me should be able to help, quite handy with these engines, also chip on here is into the let's.
ive been trying to get more pics up, tried photo bucket but dont work, got loads of build picture of my G3 can anyone help me with trying to upload so i can share me build with you ford nutters
Create an account with photobucket, upload you pics using the photobucket download system (can be done in bulk or one at a time) then click on your album, move you cursor over a pic it will reviel photo info in boxes below, copy and paste the img file info, think its the second box down, then paste onto your passionford message/thread section, paste the pics above each other like this
img/photo1/img.
img/photo2/img.
not like this
img/photo1/img. img/photo2/img.
img/photo1/img.
img/photo2/img.
not like this
Yep trying doing that just comes up with a blank box with an x in it, or is it me, put cursor over second box down copied and pasted it in to reply box and came up x in a box.????????????
Dr. Ickxs
Sep 15, 2015 10:15 PM
