Hi.. Im after the metal turbo oil return pipe .. Its for a T34.
Thanks..
there isnt a pipe for a T34 mate,there either a 2 or a 4 wd item
if you are fitting it on to a 2wd car you need a 2wd pipe (unless your using a 4wd manifold then you need a 4wd pipe)
