Is my throttle jammed??
Old Feb 14, 2010 | 03:51 PM
jaiscossie's Avatar
jaiscossie
Default Is my throttle jammed??
Went to put the car away before and started it up there was a clunk when i pressed the accelerator pedal, now when it starts it revs to about 4k!!! dont want to start it again like this incase it does any damage ,being stone cold.When you sit in the car the cable moves under the bonnet so im guessing it hasnt snapped? altho if you lift the pedal rather than push it in it comes out of the locating point in the bulkhead.Should it do this.?
Old Feb 14, 2010 | 05:00 PM
rstdave's Avatar
rstdave
Remove the cable from the arm on the throttle linkage (in the engine bay), and make sure the butterfly isn't jammed open. If it's all moving freely and returning to the closed position maybe the throttle position sensor has moved/jammed?
Old Feb 14, 2010 | 06:00 PM
Rob_DOHC's Avatar
Rob_DOHC
if the throttle is okay mate ie the cable and the butterfly you may have an air leak,
The car runs on enrichment at start up so an air leak will just cause it to rev, if every thing throttle related is fine have a look at the hoses
Old Feb 15, 2010 | 05:54 PM
jaiscossie's Avatar
jaiscossie
Checked the throttle and the cable and all is ok there, its a jamsport inlet so a bit different to the normal one, has a cossie iscv which i checked but not that either.Any other ideas guys?
Old Feb 15, 2010 | 06:11 PM
crazycage's Avatar
crazycage
if the throttle is closed and its still reving upto 4k then you have air leak it wont rev without air ! have a look at all the vac pipes that come off the inlet (boost gauge map sensor ect .
Old Feb 15, 2010 | 06:31 PM
Rob_DOHC's Avatar
Rob_DOHC
Sorry mate should have read your spec list, the above relates to MFI really, but should be essentially the same with efi. So do as crazycage says and have a good look for air leaks.
Rob,
Old Feb 15, 2010 | 07:30 PM
jaiscossie's Avatar
jaiscossie
Cheers buddy,would just a small airleak cause the engine with this setup to rev like like mad then?
Old Feb 15, 2010 | 07:32 PM
crazycage's Avatar
crazycage
yes mate it would
Old Feb 17, 2010 | 04:43 PM
jaiscossie's Avatar
jaiscossie
yes mate it would
Checked for air leaks and found nothing, had all the inlet off and put back together with no improvement,any other ideas mate?
Old Feb 17, 2010 | 05:16 PM
crazycage's Avatar
crazycage
un plug your idle speed control valve then start it mate.
Old Feb 17, 2010 | 06:05 PM
jaiscossie's Avatar
jaiscossie
Tried this, took it out and cleaned it to. God damm the car lol
Old Feb 21, 2010 | 11:20 AM
jaiscossie's Avatar
jaiscossie
Turned out to be the custom inlet had cracked underneath on the weld.
Old Feb 21, 2010 | 11:50 AM
bad boy rs's Avatar
bad boy rs
nitemare mate, who's inlet is it ? is it an easy fix
Old Feb 21, 2010 | 02:35 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Said up the page a Jamsport inlet.... what you thinking now mate?
Did I hear roller-bearing ITB's?
Old Feb 21, 2010 | 04:24 PM
jaiscossie's Avatar
jaiscossie
Was a one off Jamsport one,Am thinking of a different inlet but not sure what would go on with my setup?This it the inlet in the pic below
Old Feb 21, 2010 | 04:25 PM
jaiscossie's Avatar
jaiscossie
Who does these mate?
Old Feb 21, 2010 | 05:03 PM
project rs's Avatar
project rs
it's an easy fix on your inlet, if i wasn't going away tonight i'd of sorted it for you for the postage each way but you might find a like minded person on here who'll do it for you gratis with some postage and give it a good check over at the same time
Old Feb 21, 2010 | 06:13 PM
crazycage's Avatar
crazycage
if you want ill give it a good check over and repair it for free if you cover the postage.
Old Feb 21, 2010 | 08:27 PM
jaiscossie's Avatar
jaiscossie
^^ Thanks guys thats really kind of you The car is back at my tuners at the moment so see what they say when its all apart as not seen under the inlet yet.Will let you know how it goes.
Old Feb 21, 2010 | 08:28 PM
crazycage's Avatar
crazycage
tbh they will probably get it repaired for you then.
Old Feb 21, 2010 | 08:31 PM
rs_traynor's Avatar
rs_traynor
stage4 2wd cosworth
my fiesta rs turbo done that.was reving really high and had no brakes.was the pipe from the servo fell off the inlet
Old Feb 22, 2010 | 05:33 PM
jaiscossie's Avatar
jaiscossie
Getting the Jamsport inlet fixed and will sell it on am getting a new custom inlet made to a different design
Old Feb 22, 2010 | 07:18 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Titan IIRC mate...
Big daddy induction lol
mk3ste
Oct 17, 2021 10:09 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
mike elsome
Sep 14, 2015 04:08 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
cambo205
Ford Fiesta
Sep 6, 2015 07:45 PM
