Help. Re My Radiator................... :-(
Got a hole in my bucket my bucket....
actually my rad has a hole, so I need a new one.
It's a 2wd rad I think Is this the same as a normal sierra or are cossie ones different???
Does anyone have or know of one for sale???
thanks.
actually my rad has a hole, so I need a new one.It's a 2wd rad I think Is this the same as a normal sierra or are cossie ones different???
thanks.
B19 LBP, HI mate. If it is a 2wd one, not fooked I will have it off you. but I have no idea what they are worth either
I'll try and find out.
By the way, your car looked proper tough down southend on wednesday
Rossco.
Rossco.
thanks m8
was luckey to get there that nite as i was in a crash on the A127 about 2 hours b4
it is a 2wd one as it was on mine but got an alloy one for mine so my old one is just sat in my garage,
i will try and find out aswell
I have a Pace alloy rad going spare
I want to pressure test it before sale though as there was a leak but i'm 90% sure it was a hose broken inside the braiding instead of the rad!
Just do it, do it, do it, do it, do it now, fix it good, fix that rad just like you should, right now fix it good fix that rad just like you should, my neck my back & my rad with the crack
Mate have a look in the local yellow pages, i had mine re-corred at a local place and it only cost £100, the core was EXACTLY the same as the original and had no problems what so ever with it!!!!
TC-ST3
Sep 26, 2015 04:47 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
