cossie parts
Old Feb 13, 2010 | 05:07 PM
sygjim's Avatar
sygjim
Default cossie parts
exhaustseal
4*4 ar 0.48
coil
coilpack gr A
diameter 70
leads motorsport
2 amp
air injectors with loom
turbo
genuine injectors
new EGT gauge
kit injectors
rebuild kit turbos and 360
coil
bobine
hoses SFS
hoses
hose roose new t34/t35
lhd
hoses rooses new
leads
separator kit
Old Feb 13, 2010 | 05:10 PM
Karl 3dr's Avatar
Karl 3dr
How much for the seperator kit mate?
Old Feb 13, 2010 | 05:30 PM
Danny @ Enhanced Performance's Avatar
how much for your air injectors???
and where you from??
cheers danny
Old Feb 13, 2010 | 05:31 PM
sygjim's Avatar
sygjim
the kit is new, 40 delivered
Old Feb 13, 2010 | 05:33 PM
sygjim's Avatar
sygjim
cheers danny
200 delivered with the new loom
regards
Old Feb 13, 2010 | 05:36 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
how much for the escort cosworth cam belt cover the complet one and do they fit straight on a rwd saff
Old Feb 14, 2010 | 11:59 AM
sygjim's Avatar
sygjim
roose sold
sfs sold
amps sold
egt sold
bushes sold
price on group buy
Old Feb 14, 2010 | 12:16 PM
Cossie_ray's Avatar
Cossie_ray
Will the .48 housing fit on a T34 for a 3dr 2wd?
Old Feb 14, 2010 | 12:44 PM
dlf3yburt's Avatar
dlf3yburt
Default rebuild kit turbos and 360
how much for the rebuild kit turbos and 360 cheers
Old Feb 14, 2010 | 01:54 PM
sygjim's Avatar
sygjim
it s a 4wd but i think that it will fit, you should check if wastegate is at the same place
Old Feb 14, 2010 | 01:55 PM
sygjim's Avatar
sygjim
normaly sold, i will tell you ...
Old Feb 14, 2010 | 04:07 PM
jason 3dr's Avatar
jason 3dr
u still got the 90 bend roose hose
Old Feb 14, 2010 | 06:04 PM
sygjim's Avatar
sygjim
yes i have, new and t34 specs, pm offers
Old Feb 14, 2010 | 06:55 PM
dan yap's Avatar
dan yap
how much for the black roose water hoses delivered please/ Cheers.
Old Feb 14, 2010 | 07:21 PM
JohnP001's Avatar
JohnP001
How much for the pillar 2 gauge holder? What size are holes, or what gauges will they take? It's difinitely for a Left Hand Drive?
Old Feb 17, 2010 | 08:09 AM
sygjim's Avatar
sygjim
sorry, hoses solds
Old Feb 17, 2010 | 08:10 AM
sygjim's Avatar
sygjim
yes, it's a lhd.
30 delivered
Old Feb 17, 2010 | 09:21 AM
The Youth.'s Avatar
The Youth.
does the turbo housing have the hole for the lambda?
steve
Old Feb 17, 2010 | 10:38 AM
sygjim's Avatar
sygjim
steve
i will have a look
Old Feb 17, 2010 | 05:53 PM
sygjim's Avatar
sygjim
turbo housing sold
leads solds
amp solds
egt sold
turbo rebuild kit sold
bushes solds
roose hoses solds
sfs hoses solds
Old Mar 16, 2010 | 06:41 PM
sygjim's Avatar
sygjim
joint echappement
couvre courroie recoupé
couvre courroie
bobine
bobine coilpack qui etait montée sur gr A
tube diametre 70 ext
pommeau levier vitesse
2 amplis
air injectors avec faisceau neuf
Robinets de turbo
injecteurs origine
kit montage injecteurs
bobine
bobine
dump origines
divers durites pour waste, plenum, etc
sielnbloc echap
durite roose neuve t34/t35
support 2 manos
faisceaux
kit montage separateur
155lee
Sep 6, 2016 11:10 AM
Bransby
Sep 14, 2015 08:54 PM
