rear discs whats needed?
I'm currently putting my S2 back together and I'm thinking about putting rear discs on, I've seen a "kit" for sale but it is very expensive so i was wondering if there is any other way of doing it?
Thanks alot,
Ant
Thanks alot,
Ant
I bought the calliper mounting brackets, bolts and correct size spacers from west midland rs spares for 25 quid. Then i bought second hand callipers from scrap yard for 50 quid, rs2000 hand brake cable, rear disc and pads for a 2 wheel drive cossie from andrew pages knocked up a couple of copper brake lines but you may be able to use your original if they have not rusted away. Think it cost me about 150.
when the calliper is bolted to a sierra they are right at the top of the disc, but on my escort they drop back a bit causing the bleed nipple to be in the wrong position so the air goes to the highest point in the calliper where the nipple was. The only way to get the air out was to raise the calliper unbolted into its normal position open the nipple and release the air in the system, taking care not to damage brake pipe.
Hope this helps
Hope this helps
james kiely
Aug 28, 2015 08:58 PM
track.focus'd
Aug 12, 2015 05:53 PM
Graceland
Jul 31, 2015 10:34 AM
