Escort parts inc, comps, morettes brakes etc
Provisionally the following will be for sale soon (anything specific is to fit a mk5/5b escort)
16"x7 Compomotive 5 spoke MO's in anthracite x4 fitted with 215/40/16 toyo proxes all good tread and matching wheels good order, paint could do with some touch ups, think i still have the paint. £400
AVO coilovers, rebuilt by AVO. kit fronts were resealed and have had an overhaul. rears have been overhauled new seals adjusters etc and repainted stickered etc reciepts to prove.
one front spring needs replacing but they are £20+vat retail price. £250 due to me being too lazy to get another spring
Cobra Monaco S Bucket seats (black) one new one very little road use, cobra subframes (black) and two sparco harnesses (blue one has tear other as new) with cobra pads £200
RS2000 rear beam with powerflex poly-bushed mounts and poly-bushed RS anti-roll bar, Drilled and grooved discs ford pads, calipers good order, custom goodridge braided hoses £150
300mm conversion drilled and grooved 300mm st discs, mondeo ST220 fron calipers, ford pads, custom good ridge hoses £120
Escort Cosworth Morettes painted ford caymen blue, with mint lenses, bought new last year been sat on car in garage complete with bulbs wiring and bolts £200
Freak power RS2000 2wd quickshift complete replacement gearlinkage, bought new never fitted £75 cost £120
Area 6 lower arms fitted with powerflex steel/polybushes, unavailable, £100's worth without the polybushes, £75
if you think any prices are too high send me a pm
if you want anything post here
any questions ask in the relevant section
Now then fella, thought you'd sold the Escort?
What are those AVO's like out on the road? And what are they to fit as i've seen you've posted this in the RSTurbo parts section too?
James
James
it does say above... they can be set quite soft and you can use soft springs with them, its the poly / steel bushes and stiffening everything else that makes a car bad on the road
Just to save any more pm
Haven't sold anything yet as i'm still waiting for the car to be inspected by the dvla so i can get my number plate off. I'll update with pictures of the parts and everything else for sale once the number plate is off. it should hopefully be within the next two weeks.
jason_nike
Aug 18, 2019 10:53 AM
