zvh for dummies!!
Old Feb 10, 2010 | 05:51 PM
oldschoolfords's Avatar
oldschoolfords
Default zvh for dummies!!
can someone give me a lowdown on what a zvh consists etc etc! basicly a basic expliantion of what it is!
thanks
Old Feb 10, 2010 | 06:28 PM
martysmartie's Avatar
martysmartie
CVH head with a Zetec bottom end.
Martin
Old Feb 10, 2010 | 06:43 PM
oldschoolfords
is it as simple as that!!!!
does it just bolt together no messing! or is there some modifying to do?
Old Feb 10, 2010 | 07:47 PM
Oranoco's Avatar
Oranoco
If you're running it for turbo application you need to drop the compression to suit and ideally the head needs somecarefull working to prevent the power and torque vanishing past 5.5krpm
Old Feb 10, 2010 | 07:56 PM
Ginger Will's Avatar
Ginger Will
http://www.quantums.info/zvh.htm
Its all there!
Old Feb 10, 2010 | 07:59 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Dont do it lol
ZT or CVH....
Old Feb 10, 2010 | 08:05 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
nowt wrong with zvh pal, but if you're starting from scratch, then zetec turbo all the way.
my zvh is quite quick and i'd say for horsepower the cvh suffers as badly it's just the power comes in much earlier in the revs than a cvh which is why it won't rev as far, mainly due to ports in head.
i'd love to see a power curve comparisson of cvh vs. zvh all the way to 8krpm and see how they really vary at the top end.
i've only seen the drop off at 5.5krpm on a zvh and yet to see how the engine responds higher up.
what you must remember is that a zvh is a very torquey engine and as such is a bit diesel like.
Old Feb 10, 2010 | 08:06 PM
oldschoolfords
im not converting i have just bought one with the engine gone bang that was converted to zvh already! so i was wondering how it worked as i was gonna get the engine running again!
Old Feb 10, 2010 | 08:07 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
if that's the case, find out what let go and replace/rectify.
i'm running peak of 21psi on mine and no point trying to grip in the wet till fourth gear.
Old Feb 10, 2010 | 08:08 PM
Ginger Will
I would say this would make one brilliant at blasting round the B roads.
Old Feb 10, 2010 | 08:09 PM
oldschoolfords
im led to believe its the bottom end gone (chucked a rod!) but im sure there will be head damage too!
Old Feb 10, 2010 | 08:13 PM
gaz s1's Avatar
gaz s1
ive switched from cvh to zvh and wouldnt go back, much better road car, my head etc is slightly fettled tho so cant comment on one running a standard head
Old Feb 10, 2010 | 08:15 PM
oldschoolfords
which block gets used mainly?? is it 2.0 or 1.8??
Old Feb 10, 2010 | 08:23 PM
mercgrey's Avatar
mercgrey
1.8 or 2l i spoke to a lad at si tec who said if i used the 2l with standard pistond it would be low comp enough for boost
Old Feb 10, 2010 | 09:09 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i wouldn't run much boost on 2l pistons though, the 1.8's have much thicker crowns on the earlier ones and can handle boost better even after a amsll skim.
as said a zvh has a massive surge of power that the cvh never seems to have even with a wild cam or big turbo.
can't make a replacement for displacement
Old Feb 11, 2010 | 09:31 AM
sas's Avatar
sas
should be good!
http://www.sitechracing.co.uk/ford-z...uild-guide.asp
I have put this guide together.
Simon.
mk1turboestate
Dec 2, 2015 08:31 PM
Chas
Oct 5, 2015 07:13 PM
davidfordrs
Sep 23, 2015 02:26 PM
davidfordrs
Sep 21, 2015 04:23 AM
Del gsxr
Sep 19, 2015 05:53 PM
