what kind of brakes on cossie 4x4
Old Feb 7, 2010 | 08:22 PM
sygjim's Avatar
sygjim
Default what kind of brakes on cossie 4x4
what type of brakes of origin can be mounted on a sierra cosworth 4x4? calipers and discs Focus RS?
AP is the best way, but very expensive
any idea?
Old Feb 7, 2010 | 08:32 PM
dave cos4x4's Avatar
dave cos4x4
by the time you mess about trying to get other types of brakes on the saff etc...you might aswell be a proper set made to fit.
buy a set of used ones, cannot cost that much more than a hybrid set up.
Old Feb 7, 2010 | 08:37 PM
AP though excellent are overpriced imo, if you don't need this level of performance ther eare many less expensive options dependant on wheel size, std 4wd calipers are really only man enough for a action man car!!
Using the 2wd 4 pots with mounting brackets and FRS 324mm discs will give a huge benefit for the least money, sure reyland does the brackets and spacers for the calipers(body).
Old Feb 7, 2010 | 08:41 PM
105epwr's Avatar
105epwr
i went to the focus rs caliper,discs and brackets,work very well and half the price of aps etc
Old Feb 7, 2010 | 08:52 PM
KSA-Cossie's Avatar
KSA-Cossie
AP are the way to go maybe expensive but they are more than worth it.
Old Feb 8, 2010 | 06:16 AM
sygjim's Avatar
sygjim
on a cossie 4x4 ?
what are the mods to fit it ? where did you bought the bracket?
Old Feb 8, 2010 | 06:25 PM
sygjim's Avatar
sygjim
Old Feb 8, 2010 | 06:28 PM
Captain500rs's Avatar
Captain500rs
Think it depend what size your wheels are as well mate, as to what you can fit.
Old Feb 8, 2010 | 07:09 PM
sygjim's Avatar
sygjim
yes, you are true ...
it's for 17 or 18 wheels
for the 2rm, i had read that you can use EVO, FRS or Prsche brakes, but for a 4wd, i have no idea ...
Old Feb 8, 2010 | 07:24 PM
Captain500rs
I have 17's on mine and have have 6 pot calipers with 330mm discs, not to sure what size you can go upto though on 17's, but if you have 18's the brakes you mention should fit, i would imagine.
Old Feb 8, 2010 | 07:39 PM
sygjim's Avatar
sygjim
ap brakes ?
Old Feb 8, 2010 | 07:44 PM
Captain500rs
No mine are compbrake, should not think there is much difference in the size of the calipers.
Old Feb 8, 2010 | 08:19 PM
sygjim's Avatar
sygjim
price is like ap no ?
jason_nike
Aug 18, 2019 10:53 AM
mint_s2
Sep 2, 2015 08:58 AM
c20tbo
Aug 17, 2015 10:19 PM
cossie4x4
Aug 14, 2015 06:29 PM
Old ford
Jul 31, 2015 06:50 AM
