are these standard pistons??
ZETEC 1800 BLACKTOP 1999
low compression. valves and bottom end is fine.
140psi comp (turbo terriortry) im N/A tuning i dont know whats to blame for my low compression its either my combustion chamber has been made too big or these are low compression pistons?? any help please.
cheers mitch
cheers mitch
dammmm, i cant beleave the trouble im having to just find out if these are standard lol. the bore size is 80.60mm which is standard 1800 diameter....
going to just put the standard head back on (a pain as all i need to do is check the compression once ive done this...)
timsrs
22
Sep 24, 2015 08:14 PM
see lol
