ford focus 1.8 tdi
Hi im new on here so appologise if im posting this in the wrong area.
I would be grateful if someone could please try and advise me on a problem I have. I just recently replace the glow plugs on my ford focus 1.8tdi and since replacing them the car will not start.
could anyone please suggest some ideas i could try.
thank you. CD
thank you. CD
Changing the glow plugs is meant to make it start better right?...lol just check the connections on the glow plug ends on the lead that connects them all and to where it connects to the wiring loom if you disconnected that while changing.
My car didnt start one time before because i had removed an earth ring on it and the glow plugs stopped working so check any wiring that you have been fiddling with. When you turn the key to the 'pre' start stage does the glow plug symbol come up on the dash still?
