xr3i misfire can you help?
Old Feb 2, 2010 | 08:56 PM
RS turbo eddie's Avatar
RS turbo eddie
Default xr3i misfire can you help?
Bought an xr3i, it has a misfire at 3000 rpm. You can rev through it but it needs sorting. Any suggestions to the cause of it??? Previous owner put in a kent cam, ported and polished it. Some one told me it could be the cam so changed it to standard but it still has the misfire??? Any suggestions???
Old Feb 2, 2010 | 09:11 PM
mechanic28's Avatar
mechanic28
have you checked the basics?spark plugs/leads,cap etc?
Old Feb 2, 2010 | 09:17 PM
rich123's Avatar
rich123
if its none of the above get a tester and go round the elecs make sure everyting is powering right
Old Mar 15, 2010 | 02:34 PM
Roberto_98's Avatar
Roberto_98
How ye lads
i had a problem like that on my mk 4. turned out to be a bad connection on the alternator. hope this helps!
stephenb4506
33
Oct 2, 2015 06:25 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
