Ever had a cow sxxt on your motor ?
Driving to work on Tuesday
Get to station, park up, get out, turn to the rear door to get coat to be faced with cow sxxt from roof to sill over door & rear quarter
& its a RR so not low to the ground
Took about 5 mins to work out that i had been next to a cattle truck at the lights & one of the beasts obviously relieved itself from the top shelf
Lucky it was the rear as the front window was OPEN
So take note all you cabrio drivers Especially when the weather gets better
You never know
Hope it means good luck for 2005 though
& its a RR so not low to the ground Took about 5 mins to work out that i had been next to a cattle truck at the lights & one of the beasts obviously relieved itself from the top shelf
You never knowHope it means good luck for 2005 though
I have
Was following a tractor pullin a trailer full of it. When sh!t loads fell out the back in a massive lump
. From my front bumper to my tailpipe under the car was covered in it. I spent fookin hours cleaning under my car. My neighbours kept complaining about the smell aswell.
Bad luck M8
Had a seagull s**t through my open window once though
went all over the seat belt and down the side of the seat
fooken stunk and was a nightmare to clean.
Originally Posted by Stu.H
start of 2005 and uve been shat on
maybe u will have good luck as it wasnt the front window
Mind you
Imagine how to explain to the boss that you`re going to be late in as covered in Tom Tit
I`d never live it down
Originally Posted by martin-reyland
dangerous............. are you sure the poo did'nt come from inside your range? perhaps the dog had a back fire?
Dont think Max had any involvement in this one
Recon he prefers your workshop
