ACT Sensor and Knock Sensor???
Old Feb 2, 2010 | 05:59 PM
escort_rst's Avatar
escort_rst
Default ACT Sensor and Knock Sensor???
hi, my timing is retarding on boost so need to check if my ACT sensor and Knock sensor is working correctly. what do i do to check them? want to make sure its not one of these before i replace the ecu.
Thanks
Old Feb 2, 2010 | 09:22 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Only way to know for sure is try a known working one or a brand new one in their place.
Old Feb 2, 2010 | 09:31 PM
escort_rst's Avatar
escort_rst
are act sensors not just a ntc though? so surely if i put a multimeter on both connectors then heat up the sensor a biti should see a resistance?
Old Feb 2, 2010 | 09:39 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes but you nee to know what it's suposed read at certain temps to be able to know if it's correct or not.
Old Feb 2, 2010 | 09:46 PM
Chopshop85's Avatar
Chopshop85
My knock sensor was actually causing alot of havok . The rolling read out looked like it was drawn on a etcha-sketch!! One way to tell that its playing up.
Old Feb 3, 2010 | 09:06 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
act sensor is an easy one to test, should be around 65-70k ohms at 5 degrees, about 2500 at 90 degrees or there abouts, same as coolant sensor.
Old Feb 3, 2010 | 07:08 PM
escort_rst's Avatar
escort_rst
my rolling road printout wasnt that bad really,
cheers xr2wishy will check tomo when im at work.
anyone know how to check a knock sensor? if not i might aswell just buy one. where from and how much? cheers
Old Feb 3, 2010 | 07:14 PM
Rob_DOHC's Avatar
Rob_DOHC
Any one know what happens if you unplug the sensor? does it just stop reading ie no knock, or does the ecu just retard the ignition (for safety).....
If you can just unlug it, i would give that ago so long as you have some det cans whilst setting the car up.
Old Feb 3, 2010 | 07:19 PM
escort_rst's Avatar
escort_rst
apparently if you just unplug it the ecu doesnt get a signal at all and wont run properly
Old Feb 3, 2010 | 07:23 PM
Rob_DOHC's Avatar
Rob_DOHC
Maybe put a multimeter across the knock sensor to see if you can short the connector some how to fool the ecu into thinking it has a sensor? Tbh i haven't ever had any problems with knock sensors so haven't taken the time to learn how operate. Know the basics just don't know how many outputs the sensor has etc.
Rob,
Old Feb 3, 2010 | 11:32 PM
Chopshop85's Avatar
Chopshop85
You can leave it plugged in but unscrew it and cable tie it to a rubber hose or somehting in the engine that wont vibrate. The car will run great if it is the knock sensor playing up.
Old Feb 4, 2010 | 07:28 AM
Rob_DOHC's Avatar
Rob_DOHC
That's easy to do as well lol
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
