Motor oil level problem Cosworth 4x4
I park my Sierra Cosworth 4x4 into my garage. After 3 days i check motor oil level and it was too low. After 7-8 days car in garage i check oil level and it was increase to normal level.Why my oil drop too slowly ?
I check this several times and every time the oil level increase if i dont drive the car and dont start the engine 8-10 days
The cylinder head and its components hold lots of oil back and takes ages to drain down to the sump, this is normal !
Its always best to check the oil in the car when its cold on a level surface of course as it is easy to overfill the engine.
Because all of the oil retained in the head takes a long time to drain though tiny holes..... You should run a cossie about 2-3mm below the max mark on the dipstick, prevents excessive breather losses and allows for a bit of drain-down. Don't worry about it, if it was using excessive amounts, or the oil level was rising, then it would be time to worry
Reviving an ancient post perhaps someone can shed some light. Have exactly the same issue as the OP and it doesn't seem right to me. It takes a week for the oil to go back to its original level! Any other thoughts? Strangely enough, if I top up the oil, it shows on the dipstick almost immediately.
Engine oil level should be checked after the engine has run, if you use this rule "check engine oil level every time you fill up with petrol". your oil level should be at the upper level when checked.Waiting days for the engine oil to drain back is not the way to check the level.
My oil level on my 2wd Saff never fluctuates and is always up to the correct level.
Just re-read my post no. 17, your oil level should be near the max level after the engine has run. If you check the oil level every time you fill up with petrol the oil will be hot and have expanded, the level should be set to around the max never above. If you follow this method you will never be caught out with low oil level and oil surge issues
( what oil do you use? ) should never have an issue with it taking a long time to run back down into your sump.If your engine/turbo is in tip top condition and you fill it with the correct amount of oil it should not be using oil and the level should stay the same. I have never heard of this problem that you have and there does not seem to be a logical reason for it to happen. Check the oil level before you take the car out and there is no reason why when you check it again it will be different. An engine can only use oil through valve guide seals, worn piston rings, turbo oil seals or actual oil leaks. If your engine has none of these issues the oil level should not change.
My 4x4 also has the 'problem' that it takes a lot of time for the oil to drain back to the sump. I don't know why this is, but it can take a few days before the oil level is stable.
Your climate in Malta is a lot warmer than it is here in the UK so the oil you use
The only thing which could change the level would be a breather system that is filling up in use and then draining back to sump but for that to happen it would have to be installed incorrectly.
How does the oil drain back from the head to the sump on a YB? My BOA has a timing chain where it is completely open where the oil can flow back and it has a drain hose from each head to the sump. But the YB doesn't have a timing chain in oil or a hose back to the sump (as far as I know).
high performance pinto's back in the day had twin braided lines fitted from head to sump.
There are two anti-drain back valves in the Yb engines lubrication system, one is in the oil filter the other is in the cylinder heads main oil supply gallery. Typically if these are faulty and allowing the oil to drain back you will notice a delay in the oil pressure rising on startup and tappet noise/ big end rumble until the oil has refilled the filter and galleries etc and normal pressure has been reached.
You need to set the oil level after the engine's lubrication system has been primed.
If you suspect there may be a drain back issue with aftermarket breathers and modifications and you have no idea how much oil is actually in the engine it may be wise to drain the oil and refill it with the correct quantity and then re asses
Also oil pressure build up on gauge would depend on many factors oil grade or using a high pressure pump etc.
I wonder if he has a oil cooler ?
Paul
So why does Ford state in the owners book that the cosworth engine uses 1.75 pints per 1000km even when new dependant on use...
If your running it first then taking a measure a lot of oil will be through the system so its either half way up the dips tick when warm or completely full on cold. If it's full on the dips tick after a run then it's over full when cold. Drain it and put in the stated amount and see where it lands. Check it under the same condition to keep an accurate measure.
If the correct amount of oil has been put in, it can only ever need maybe a slight top up it cant make extra oil all by itself. I have had my 2wd Saff for 23 years and never had any oil level problems so is this something that just happens with the 4X4 Saff?
big_Rad
Sep 15, 2017 09:36 AM
charliecosworth
Aug 19, 2015 02:00 PM
Aug 14, 2015 07:29 AM
