lowering my focus problem
Old Feb 2, 2010 | 01:13 PM
zammofocus's Avatar
zammofocus
Default lowering my focus problem
i lowered my 53 focus and the drive of it is horrible feels like it on ice like my back wheels wana go a different way . and when i go on a motor way the car sways feels like im gona lose control what could this be please help
Old Feb 2, 2010 | 03:12 PM
drewjsy's Avatar
drewjsy
focus drew
wot kit have u used??
Old Feb 2, 2010 | 03:16 PM
zammofocus's Avatar
zammofocus
i used an eibach pro kit 40mm drop
Old Feb 2, 2010 | 03:20 PM
craig_southampton's Avatar
craig_southampton
did you do the shocks as well or just springs
Old Feb 2, 2010 | 03:21 PM
zammofocus's Avatar
zammofocus
no i just replaced the springs just feels bad
Old Feb 2, 2010 | 03:23 PM
craig_southampton
do the front wheels look like there cambering at all
Old Feb 2, 2010 | 03:27 PM
zammofocus's Avatar
zammofocus
they look fine too me tbh
Old Feb 2, 2010 | 03:31 PM
craig_southampton
im not to sure wot would cause this but some 1 on here will tell you. did u cut the bump stops im not sure if you have to but just a idea.
wellcome to pf by the way.
Old Feb 2, 2010 | 03:36 PM
zammofocus's Avatar
zammofocus
no i didnt just took the springs out and put the new ones in didnt cut anything
yeah im a noob at this forum business
Old Feb 2, 2010 | 03:42 PM
You need to do the shocks, as well for best benefit, but I would get tracking checked if feeling floaty.
Old Feb 2, 2010 | 03:49 PM
zammofocus's Avatar
zammofocus
so u reakon tracking yeah thats how it feels like i light (floaty)
Old Feb 2, 2010 | 04:05 PM
steves24V's's Avatar
steves24V's
get front and rear tracking done the rear lower arms have off set washers to adjust it, if you took them out and there back in differnet places could put your rear tracking well out
Old Feb 4, 2010 | 05:41 PM
RichieST's Avatar
RichieST
You didn't undo the bolts that fix the rear trailing arm to the rear subframe did you? If so that will have knocked out the alignment of the rear wheels. Get it on a proper 4 wheel laser aligner and see what happens!
Old Feb 4, 2010 | 07:17 PM
zammofocus's Avatar
zammofocus
yeah i think so my mate fitted them i thought u cant adjust the rear axle
Old Feb 4, 2010 | 09:49 PM
RichieST's Avatar
RichieST
Those are the ones that you shouldn't undo! Pretty sure they adjust the camber, think they call them wobble bolts or something like that, basically turn them a bit and the camber changes. Best get it in for proper alignment!
Old Feb 6, 2010 | 09:48 PM
pdfbt40's Avatar
pdfbt40
Most likely tracking on front. It should always be checked after dismantling the suspension.
The inner bolts of the lower spring arms of the rear suspension are eccentric, as Rich170 says. Ford say they are to adjust the toe, but due to the design of the SLA suspension it slightly changes camber as well.
Martin
Old Feb 10, 2010 | 03:55 PM
zammofocus's Avatar
zammofocus
cheers guys uve been a real help
Old Feb 10, 2010 | 04:39 PM
cootsie's Avatar
cootsie
wobble bolts.... i like that...lol
They are indeed for the Toe the camber is fixed but you might find you will get some leeway if you loosen all the bolts. You need to make sure the eccentric bolts that bolt the bottom arms to the rear beam isn't seized in to the bush in the arm
But you will need to get it the alignment set again 4 wheel alignment is best
If camber is still not within the spec you will need these
cheap way
or
Old Feb 10, 2010 | 06:14 PM
JesseT's Avatar
JesseT
My vote goes for the rear toe-in being all over the place.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Sheepdisease
Aug 30, 2015 09:11 PM
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
A.t.p
Aug 15, 2015 11:37 AM
