boost leak not ford
i had a boost leak on my evo 3 it took me ages to track it down but do what i did, take all the boost pipes and intercooler pipes off and give them a good check , also take the actuator off and check its holding pressure, all i did was take off all the pipe work off and put it back on and all was fine
andy
andy
If it had a boost leak it'd be boosting low all the time wouldn't it? Do you know how the standard management controls the boost, solenoid or anything?? If it's an easy enough job to do the actuator i'd be definately changing that first off!
JoeyBoyden
Aug 18, 2015 10:52 PM
Gadget
Aug 13, 2015 08:19 PM
Escortdriver1
Jul 31, 2015 02:36 PM
