Mods needed for nurburg 2010
Old Jan 30, 2010 | 06:39 PM
rstubby15's Avatar
rstubby15
Default Mods needed for nurburg 2010
Ferrys all booked up so nurburg here I come! Got me thinking though, what mods to my S2 RS Turbo are gonna be needed to fully enjoy it and to prevent any mishaps. Any ideas people?
Old Jan 30, 2010 | 06:45 PM
B16JUS's Avatar
B16JUS
the ring isnt about power is about knowledge and carrying the speed through the corners, so i would say suspension and brakes then power.
J
Old Jan 30, 2010 | 06:50 PM
rstubby15's Avatar
rstubby15
J
Powers solved, but I shall be taking it very slowly at first as i will be absolutly devastated if I stuff it. Got a GMAX suspension on her, escort cossie brakes (ABS Removed) and powerflex bushes all round. Anything else you think I might need? Would a baffled sump be a good idea as I dont want the engine going pop!
Old Jan 30, 2010 | 07:18 PM
Tango Ford's Avatar
Tango Ford
shouldnt need baffled sump as you learn it ,you not gonna break any lap records first time round ,just make sure engine,box are fit ,steering,suspension in good nick and dont try to be a hero
Old Jan 30, 2010 | 07:25 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
brakes, brake fluid, tyres
Old Jan 30, 2010 | 07:28 PM
jammerrs's Avatar
jammerrs
massive service and check everything
Old Jan 30, 2010 | 07:43 PM
Ginge !'s Avatar
Ginge !
just finding my feet
decent brake fluid, decent brake pads and a decent balance on your credit card should you pelt the barrier pmsl
Old Jan 30, 2010 | 08:07 PM
mike s2 rst's Avatar
mike s2 rst
its a good idea to get some cooling to your brakes!!remove you foglights and some cheap ducting tube or something like that because there gonna get HOT!!
Old Jan 30, 2010 | 08:30 PM
Rick's Avatar
Rick
pads, bushes, geometry, cooling system all need to be spot on.
Old Jan 30, 2010 | 08:47 PM
Ginge !'s Avatar
Ginge !
part ex it at a local "hummingbird motors" is my advice
matman
Sep 9, 2015 05:45 PM
no1trancefan
Ford Focus ST
Aug 7, 2015 09:21 PM
col93saphcos
Aug 7, 2015 03:21 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
Escortdriver1
Jul 31, 2015 02:36 PM
