escort gti matrix change easy or not ?
hi guys after eventually gettin my escort running
i topped up with water etc after doing the head gasket got
everything topped up now ready to start disaster i now have a swimming pool in the car
the matrix is burst so is this a dash out job or possible to do with dash in
any tips or hints would be good cheers kev
Graceland has changed one on his escort and he said it wasn't the easiest of jobs....think the dash has to come out.
If it's anything like the 2i, I know my other half is waiting to get the car up the Gracey's to use the pit cos the pipes run too close to the cross-member and he couldn't get to them from jacking it up on the drive.... so I am still cold.....
it is a dash out job mate and tbh it isn't that much of a ball ache just time consuming the dash is only held in with torques screws, sure you'll be fine and it'll be alot better than the mobile swimming pool you have at the moment
dash out but they are very easy to do ,simply put ,drop battary leads,unplug connecters from top of fuse box,remove steering wheel,unscrew heater controls,remove instuments unscrew dash and remove you then have asses to the heater
