Fitting Sierra adjustable top mounts
Old Jan 29, 2010 | 03:16 PM
Shaggy's Auto Store's Avatar
Shaggy's Auto Store
Default Fitting Sierra adjustable top mounts
These are the top mount they i have ordered for my track car. Can anyone tell me if i will need to cut a bit out of my chassis/ strut top to allow them to be adjustable. They havnt arrived yet im just trying to get a picture how they work.. Thanks in advance
Check out my profile for pics so far..
Old Jan 30, 2010 | 09:54 AM
Shaggy's Auto Store
Someones bound to have had experience with these ...?
Old Jan 30, 2010 | 09:55 AM
RONNIE AMIS's Avatar
RONNIE AMIS
dont think you need to do any cutting mate,
try posting this in general discussion, will get more views probably
Old Jan 30, 2010 | 11:16 AM
Shaggy's Auto Store
Thanks Ronnie ive moved the thread now.. Im new here so just finding my way..
Old Jan 30, 2010 | 11:34 AM
RONNIE AMIS
cool mate, welcome.
i'm sure you'll get more help in their
Old Jan 30, 2010 | 02:41 PM
Char1ie's Avatar
Char1ie
You'll need to drill holes. And your challenge is to make the holes equal on each side. You could do four or six on each turret. You'll need to make sure that each plate is the same distance from the front of the car, and equal distance from the centre of the car, then make sure that the holes are aligned so that each plate is at the correct angle.
Imagine your plate is a clock. Both plates 12.00 marker should point forwards. Then you'll need a hole at 2.00, 4.00, 6.00, 8.00 and 10.00. This is difficult to get right.
I made a measuring device like a clock with hands fixed two hours apart. Drill one hole at 12.00 and the other hand will point to 2.00 so you know where to drill.
It's a royal pain in the arse. A horrible fiddly job.
Charlie
Old Jan 30, 2010 | 03:16 PM
lacey's Avatar
lacey
i got them on my motor. I have different strut tops now but i did have them mounted on the std struts at one point there not that bad to do just take your time dont rush and once you have one hold drill then you will stop shitting it no one whats to drill holes in the wrong place. And another thing to take into account is if your running a strut brace coz you what to try and get the holes on that to line up aswell but not all brace will have the same pcd as the top you have. Hope this is of a help
Old Feb 1, 2010 | 08:07 AM
Shaggy's Auto Store
Fantastic this Passion Ford thing seems the business.. Thanks Charlie for the detailed describion and the pictures, nothing like starting something blind and making a balls up... Think i might be for cutting a set of strut terrots out of another car and welding them on top of mine to lower the car down an inch and regain my shock travel.
matman
Sep 9, 2015 05:45 PM
155lee
Aug 14, 2015 11:21 AM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
Vincereese
Aug 11, 2015 08:44 AM
