s2 radiator the same as s1??
Old Jan 28, 2010 | 08:37 PM
smitsturbo's Avatar
smitsturbo
Default s2 radiator the same as s1??
i cant get all the hoses & radiator to fit snugly into my s2, the radiator & engine is from a s1, also does anybody have a sort of diagram for all the water hoses at the rear of the engine please,
cheers
Old Jan 28, 2010 | 08:49 PM
dangerousbrian's Avatar
dangerousbrian
the radiator outlets are different but dont know about size..also some of the hoses are different..water pump hoses is the 1 that springs to mind
Old Jan 28, 2010 | 09:12 PM
s1cab's Avatar
s1cab
i think they are slightly different.. the bottom hose connection on the series 2 radiator is slightly angled if i remember right. but im sure someone else will confirm this
Old Jan 29, 2010 | 01:39 AM
smitsturbo's Avatar
smitsturbo
cheers
Old Jan 29, 2010 | 06:39 AM
mr_joe0606's Avatar
mr_joe0606
Is your turbo a series 2 or 1 s2 rads have a water feed pipe going into it s1 does not.
Old Jan 29, 2010 | 07:15 AM
Oranoco's Avatar
Oranoco
Totally different. S1 doesn't have the take off for the turbo's water cooling.
Old Jan 29, 2010 | 07:32 AM
Lincolndanny's Avatar
Lincolndanny
Totally different in every way. Different mounting points, no turbo coolant return etc
Old Jan 29, 2010 | 08:21 AM
project rs's Avatar
project rs
are you using a serires 1 turbo too if so it'll all fit
Old Jan 29, 2010 | 12:53 PM
smitsturbo's Avatar
smitsturbo
im using a s2 turbo, i have the top radiator hose its the botttom 1 im having trouble with but i think ive sussed it
Old Jan 29, 2010 | 01:04 PM
mr_joe0606's Avatar
mr_joe0606
The water hose at the bottom off the turbo goes to the radiator on a s2.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
