Power/torque Grp A and WRC
Hi all, hopefully this is THE forum to ask
Do you guys know what kind kind of power/torque figures these cars "really" had?
on various websites etc.. a Grp A Escort has 300hp and 400nm, and a WRC around 320hp and 500nm. But these numbers must be way to low, I saw an ad in
"rallycarsforsale" and this particular Escort WRC had 340hp and 612nm........, same goes for the Focus WRC, M-Sport web site, says 300(max FIA) and 550nm. Rumors say 800nm+...
10-11:1 compression ratio. A IHI turbo at around 38psi at 3000rpm, high quality fuel and very careful mapping!
The 300bhp comes early in the rev range and at the top of the rev range still has 300bhp. This is due to the boost levels, 38psi asap and 7-9psi at 7000rpm.
The restrictor is the problem, if you run too much boost the post restrictor depression gets too high and the turbo will, in short, die
Iirc down to the turbo overspending trying to suck through more air than possible
Restricted engines are so weird, the power curve is almost exactly flat and the torque just drops off linearly with RPM.
Its mental they are as fast as they are considering the horrible shape, but obviously correct gearing is very important.
520lbft in first off the line on a full bore launch must be pretty epic though, would love to experience it!
They only maintain peak boost for a few hundred rpm though, and then the boost just totally dies as revs increase, they lose a psi every couple of hundred rpm basically.
I'll show you a graph as chip also wants one I'll upload tonight guys. The graph I'll show you is what went into juhah kannkunan wrc escort when Mark jasper had it
Awesome engine. Give me till tonight
Ps ment to say, the dyno would not hold any more torque that low, it would pull that boost at 3000rpm and lower.
After a word with the old fella he said 520-530lbft was possible from this at higher boost levels! And has been seen before
Totally bizzare graph, literally almost flat power curve and a totally horrific shape to the torque curve, just plumetting the moment revs rise.
I'd hate to have an engine like that! So glad restrictors arent part of the MOT, lol
Its amazing how quick the cars manage to be in spite of that!
I believe they typically change at about 5K but obivously if pulling out of a corner and not wanting to change gear and unsettle the car they hold on longer.
Boys bear in mind the GpA restrictor started at 40mm, then dropped to 38, then 36 and finally 34mm. 40mm and the motor would still rev to well past 7000.
Horses for course but what year horse, eh?
Interesting thread.
How would an engine of Grp A / WRC spec compare to a Stage 3 in terms of driveability, power delivery, power & torque graphs etc? I'm just wondering why people don't commonly have their YB's specced in Grp A / WRC configurations if their torque figures are so impressive?
Because it costs a fortune to do it correctly. Stage 3 is only a few hundred £. I'd imagine proper group a spec is well over £15K once you factor in the ALS system etc.
Well it really depends on the engine. Group A is used for all and nothing those days. Real group A engines were built by Mountune with expensive parts and needed rebuild a lot more often than you might think. On the other hand you find the so called "clubman" group A engines which are just uprated engines with driving ability you find on rally engines (lot of torque mid-range and fast response). These are much more reliable.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
