Small Turbo cosworth sensors
Old Jan 27, 2010 | 01:33 AM
robreg5's Avatar
robreg5
Default Small Turbo cosworth sensors
Hi people. I am after some ford part numbers. Does anyone know the part numbers for the standard map sensor, air charge temp sensor and water temp ecu sensor for a small turbo escort cosworth?? Any help is much appreciated
Cheers Robbi.
Old Jan 27, 2010 | 10:59 AM
YBT200's Avatar
YBT200
hi , water temp sensor finis no is 6810428
Old Jan 27, 2010 | 11:01 AM
grcossie's Avatar
grcossie
Here you have it
Ect 6810428
Act 6740335
Map 6924087
Maf 6848044
Old Jan 27, 2010 | 02:43 PM
robreg5's Avatar
robreg5
Cheers Lads
Old Jan 29, 2010 | 11:52 PM
robreg5's Avatar
robreg5
Hello again Does anyone know of a good method for checking all these sensors as im having some funny boost probs. Plugged in a code reader to the 3 pin plug under the bonnet and it gave me fault code 128-map sensor/vacuum hose fault. Have checked all vacuum and boost hoses and they all look in good order with no visable damage or leaks.
Old Jan 30, 2010 | 12:02 AM
robreg5's Avatar
robreg5
also does anyone know the correct way to test the lectron valve/solenoid?
Cheers Robbi
j.hammond1
30
Oct 31, 2021 05:28 PM
3i Jim
Nov 20, 2015 05:12 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
muz
Aug 16, 2015 12:57 PM
Aug 14, 2015 07:29 AM
