rs1800
the rs1800 fiesta high output cast alloy inlet manifold is the same as the early 2.0 litre silvertop engine as these also came with the alloy inlet which was then later swapped to the plastic one. just make sure its got HO stamped on the side as th LO inlets ports are alot smaller.
cheers paul
cheers paul
bassboy
Fiesta RS1800/RS Turbo
Apr 17, 2005 12:54 AM
