Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
crossflow camshaft question
Old Jan 24, 2010 | 07:15 PM
ShandzS1's Avatar
ShandzS1
Default crossflow camshaft question
ive got a 1.3efi ohv and the camshaft is knackered.
but i can get a 1.3 carb engine for bits / bottom end?
question is will the cam / bottom end be compatible with it being efi?
Old Jan 25, 2010 | 12:38 PM
So long as the carb engine is a FWD engine, the X flow cam will not fit a valencia engine(fwd) as the X flow cam is longer.
Old Jan 25, 2010 | 09:41 PM
ShandzS1's Avatar
ShandzS1
both are fwd, but will the carb bottom end work with the efi?
Old Jan 26, 2010 | 02:04 PM
As long as you can put the sensors needed on it, which will be crank sensor and cam sensor, never had a good look at a efi lump in these so don't know where or how fitted.
Old Jan 26, 2010 | 10:30 PM
ShandzS1's Avatar
ShandzS1
Thanks, picking up this wk, so will found out soon enough.
Nov 1, 2015 06:53 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
mondeomark
Sep 28, 2015 06:28 AM
