idle screw ?
Old Jan 5, 2005 | 01:16 PM
220TC's Avatar
220TC
Default idle screw ?
Hi,
Next to the throttle position sensor on my s2 erst there is a large screw facing upwards with a spring on it, anyone know what it is for ?
cheers, Duncan
Old Jan 5, 2005 | 01:26 PM
CabrioTurbo's Avatar
CabrioTurbo
yes you can adjust the idle with it not sure if its actually intended for soley that purpose though...
Hrsturbo's Avatar
Hrsturbo
idle screw to change idle speed, as you said in the topic
Old Jan 5, 2005 | 01:35 PM
Alan s1's Avatar
Alan s1
It ajusted the idle but if its out to far it will not boost as someone played with my m8s and every time he put his foot down it just cucked the boosted into the exsursted
Old Jan 5, 2005 | 01:42 PM
220TC's Avatar
220TC
ah right, so what is the other smaller screw for that sits on the bracket at the end of the throttle cable, I thought this did the idle speed ?
fordrallycar
Sep 30, 2015 07:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
hopper350
Sep 4, 2015 12:53 AM
