Can wrong spark plugs cause hot runing?
Old Jan 5, 2005 | 12:24 PM
zvhturbo's Avatar
zvhturbo
Default Can wrong spark plugs cause hot runing?
As above.
My car has always ran a bit hot and i've replaced everything.
The last thing now is the spark plugs.
I have some Denso P8 plugs at the moment.
Matt.
Old Jan 5, 2005 | 12:46 PM
pugo's Avatar
pugo
no, plugs cannot, however incorrect ignition timing, fuel air ratio, coolant/antifreez ratio , worn engine can all cause hi temps as can blocked cooling systems, faulty rad caps etc
its a mine field but keep looking for it
Pugo
Old Jan 5, 2005 | 01:06 PM
zvhturbo's Avatar
zvhturbo
Well the rad, intercooler, hoses, engine are all new and the coolant is Ford on a 50/50 mix, it also has a new rad cap.
It does however have a new engine management system which has not been mapped yet.
So perhaps its the ignition timing.
At least i don't nee to buy new plugs.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
