Gearbox/Speedo puzzle!
Old Jan 5, 2005 | 12:19 PM
rich101's Avatar
rich101
Default Gearbox/Speedo puzzle!
Hello and HELP!!!
(this is all in a kitcar btw)
I've got a t5 gearbox from a sierra cosworth (around '88) and I've got the speedo cable for it, however there is no way to connect the speedo cable to the box.
At the normal cable connection point there is only some kind of insert in the usual speedo drive hole, this insert has a small (about 5mm wide and 5mm deep) threaded hole in it.
Has anyone got any ideas? Was there an electronic/magnetic pickup on some of these 'boxes, or will I need to fit a new speedo drive, if so where can I get one of these from?
Thanks,
Rich
Old Jan 6, 2005 | 08:24 PM
dark3drcos.kickass's Avatar
dark3drcos.kickass
it is mechanical sounds like someone has blocked it off speak to paul at north yorks rs spares or pete at rs specialist you will find these in traders section easily
Old Jan 7, 2005 | 06:55 AM
rich101's Avatar
rich101
Thanks,
I'll give them a go!
CossieRich
30
Sep 8, 2015 10:08 PM
RC4
Jun 23, 2007 06:36 PM
Porkie
Mar 6, 2007 03:01 PM
Westy
28
Feb 4, 2007 02:36 PM
Nick_RSIFEZ
Jan 19, 2007 04:06 PM
