newbie, escort van clutch problem
hi folks
w reg 1.8 55d
i cant get it into any other gear than reverse (presume the clutch is shot?)
can i adjust it? other than altering the position of the arm on the box?
cheers
w reg 1.8 55d
cheers
to be honest chap i am not entirely sure? i was traveling approx 150 miles per day to and from work and it started to deteriorate ie crunch into gears untill now being stuck at my work
the clutch wasnt slipping or any thing but selects evey gear nice when engine is off?
any 1?
or is it just a case of no adjustment! replace the clutch etc?
just wanted it home to change the clutch instead of having to do it at the works car park
cheers
cheers
i did notice that on the pedal, i have just bit the bullet and put it into the garage as i am stuck for time and need the van on the road asap for work
cheers for your help tho m8
jessie_rs
11
Jun 3, 2019 04:57 PM
