Fixing Nokias
Old Jan 5, 2005 | 11:07 AM
Martyn's Avatar
Martyn
Default Fixing Nokias
The missus split some Sprite on hers last night and didnt realise till awhile after Luckily it was diet so not as much suger in it
Gave it a good clean but since turning it on one of the keypad LEDs is staying lit up but only dim. Any ideas or is it fooked?
Old Jan 5, 2005 | 11:13 AM
gus's Avatar
gus
have you tried the throwing against the wall method
or just threaten it first, if that fails then throw it
Old Jan 5, 2005 | 11:15 AM
The DIVA's Avatar
The DIVA
You`ll have to strip it mate and get the rest of the sprite out,turn it off as well and remove the batt until its been cleaned or it could go bang permanently...
What model is it is it one you can pull the covers off easily ?
Old Jan 5, 2005 | 11:31 AM
Martyn's Avatar
Martyn
Its a 6610i
Old Jan 5, 2005 | 02:58 PM
Andymancos's Avatar
Andymancos
sorry to say mate its fooked or will be fooked within a month permanently trust me i fix them for a living we dont even bother trying to fix them it causes so many problems, The moment u spill liquid onto electric components they start shorting out with each other eventually it will dry out and leave a mouldy look on the components which causes dry joints to the solder.. BIN IT and get a new one
Old Jan 5, 2005 | 03:02 PM
CabrioTurbo's Avatar
CabrioTurbo
as above really.. its hard to fix if its been submersed (especially if swiched on while doing so) as it shorts it out or the water ingresses into the boad fucking the conections...
You could try removing the facia and unscrewing everything.. cleaning as you go but my betting is that it is/will be buggered
cheeRs
Phil
Ps andy what cossie you got.. not far from me!
Old Jan 5, 2005 | 10:12 PM
Martyn's Avatar
Martyn
Well its working fine at the moment! It was totally covered in liquid, it basically soaked thru the bag it was in, so maybe she got off lightly!
Old Jan 5, 2005 | 11:23 PM
Andymancos's Avatar
Andymancos
Mate ive seen fone's be buggered just through people's sweat when there out running its the current that slowly fucks the board up stick it on charge for a few days and you will see what i mean
Old Jan 5, 2005 | 11:29 PM
mark_J's Avatar
mark_J
Same happened to mine and I left it in the boiler cupboard for a few days and it was as good as new!
Russ Payne
Sep 25, 2015 08:29 PM
Ronnie Scott
Sep 20, 2015 10:21 PM
Cos500
Sep 16, 2015 09:50 PM
landaqmabba
Sep 15, 2015 07:16 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
