Mongoose 4x4 cossie exhaust - Removing middle box
Old Jan 5, 2005 | 09:34 AM
EssexBoyRacer's Avatar
EssexBoyRacer
Default Mongoose 4x4 cossie exhaust - Removing middle box
Put a 4x4 mongoose 4" system on my car last nite, replacing the 3" mongoose system that was on there before and it sounds hardly n e different.
I find it really quiet (compard to the rs turbo). How do they sound with the middle box removed? I know u lose torque by doing this but...
Old Jan 5, 2005 | 10:09 AM
CraigN's Avatar
CraigN
didnt know you could get a 4" system for a cossie off the shelf
you sure its not the same just a 4" tailpipe
what was wrong with the 3" unless your pushing over 500bhp
Old Jan 5, 2005 | 10:12 AM
EssexBoyRacer
sorry, I did mean the tailpipes, both were 3" bore systems.
The only other difference between the two were the middle boxes. The 3" one has like a flanged section where as the 4" one has a proper silencer on it.
Old Jan 5, 2005 | 10:17 AM
CraigN's Avatar
CraigN
if they are both mongooes you should just be able to swap the backboxes
they are loud with the middle box removed
depends on your spec i have a mongooes with 3.5" tail and a centre box and mine is a nice sound
Old Jan 5, 2005 | 10:20 AM
TIFF's Avatar
TIFF
Chasing Radders
Proper loud with the middle box out but sound the bollox when it comes on boost
Old Jan 5, 2005 | 10:22 AM
EssexBoyRacer
cheers guys.
Old Jan 5, 2005 | 10:24 AM
Milko Pete's Avatar
Milko Pete
Sound ALOT better with it out, do it!
Old Jan 5, 2005 | 10:27 AM
CabrioTurbo's Avatar
CabrioTurbo
It will be LOUD though! depends if you can put up with it to be honest we removed the middle box on my mates saff... god it sounded horrific! there is a constant DRONEEEEEEEEEEEEEEE when your cruising along.. and when you accelerate.... well put it this way you might want to ask for ear defenders for your birthday...
Old Jan 5, 2005 | 10:28 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
you wont lose torque either, its a turbo car, best results are from NO exhaust after the turbo, or in a normal world (ie not Indy car) just zero backpressure.
Old Jan 5, 2005 | 10:29 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
i had middle box out of mine too, and fucking loved it, sounds mental
Old Jan 5, 2005 | 10:33 AM
CabrioTurbo
is it a myth that lack of back pressure will bugger turbo seals... i read that somewhere... come to think of it im SURE it was Fast Ford
EssexBoyRacer
Loud is fine, its how I want it and i dont use the car everyday so shouldnt get annoying.
my m8 had it done on his escort cossie (i think has a mongoose) and it sounds the tits, another m8 has has it done on his 2wd saph with a scorpion system and it sounds very echo'y on idle (which Im not 100% keen on) but sounds wicked on boost. Havent heard a 4x4 mongoose on a saph yet but I've just booked it into pipecraft to have done in a couple of weeks so will have to see!
Old Jan 5, 2005 | 10:53 AM
CliffRS4's Avatar
CliffRS4
Gadget did his ages ago when he had a saff cossie.
Ask him mate and it did sound the nuts
Old Jan 5, 2005 | 11:26 AM
rstoughy's Avatar
rstoughy
Whats the best way of doing this is it just a cut out and weld in the new pipe job or is it best to use clamps.
Just wondering as it sounds like a plan for my 2WD.
Old Jan 5, 2005 | 11:29 AM
EssexBoyRacer
They're gonna weld in a replacement pipe on mine but Im sure they could make it up so that it can be clamped on instead - could then put the middle box back in you changed u're mind.
Old Jan 5, 2005 | 12:20 PM
steve rs's Avatar
steve rs
ive had mine done and i have a mongoose system sounds awesome
and it only cost £20 to get removed
Old Jan 5, 2005 | 12:22 PM
EssexBoyRacer
£20 Pipecraft want £60!
Old Jan 5, 2005 | 12:32 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Cost me 30quid and was done with FAR better quality stainless and far better quality welds than the original system
The totally changed the centre hanger into this fucking ace triangulated stainless thing that looked awesome
But was done local to me so no use to you
Old Jan 5, 2005 | 12:41 PM
Racey's Avatar
Racey
i've had the box removed from mine and it sounds farbetter than it did before. i'd recommend it. I had it done at 4Xtreme in crays hill, essex and it cost me no more than £50.
do it for definite
Old Jan 25, 2005 | 10:27 AM
EssexBoyRacer
Had it done and it sounds the bollox! Finally sounds a bit more like a cossie!
Old Jan 25, 2005 | 10:36 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
I take it without a centre box, the car will be far too loud to pass noise regs at a track day?
Old Jan 25, 2005 | 10:38 AM
EssexBoyRacer
I dont think mine would be a problem as its standard and generally isnt that noisy - even at full boost.
My m8s 2wd scorpion box however I reckon would be too loud.
Old Jan 25, 2005 | 10:45 AM
Ish's Avatar
Ish
correct!
Old Nov 17, 2012 | 08:19 PM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
Do anyone have any videos inside/outside a Cossie which has had the 3'' stainless steel exhaust centre box removed? I'd like to hear a samples as Im planning the removal of Mongoose 3'' middle silencer...
Old Nov 17, 2012 | 08:30 PM
LHD220Turbo's Avatar
LHD220Turbo
my advise is not to remove it, its too loud in my opinion, it will sound good for a few days but you'll soon get bored of the noise it makes
Old Nov 17, 2012 | 09:15 PM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
Yes, infact it's loud enough with the middle box, I was just thinking of removing it as it took fair a bit of punishment from a pothole. I'll probably stick with it to retain some sort of refinement in cabin but if anyone have any sound samples of Cossies running single silencer exhausts I'd like to hear them just for curiosity.
Old Nov 18, 2012 | 07:35 PM
CosKev3's Avatar
CosKev3
Middle box removal is ok with the Mongoose systems,but don't do it to a Scorpion as they have a tiny back box and sound dreadfull!!!
Didn't find my Saph loud at all with middle box removed,just made the burble at idle sound real nice.
Old Nov 19, 2012 | 05:18 PM
GUZZLER's Avatar
GUZZLER
I had one with the centre box removed, sounded abut to chavvy to me but each to their own
Old Nov 19, 2012 | 05:31 PM
plynchy's Avatar
plynchy
I've still got my centre box, but all the baffles blew out a long time ago...
It was 94dB static at Rockingham yesterday, on boost it's a lot louder though, plus the occasional explosion between gear changes doesn't help.
Old Nov 19, 2012 | 07:43 PM
RS SHAUN's Avatar
RS SHAUN
Mine's been removed, and thinking about getting one put back in!
CLIVE
Oct 2, 2015 12:58 PM
track.focus'd
Aug 12, 2015 05:53 PM
blakey100
Aug 4, 2015 08:17 PM
jdsjojo
Aug 1, 2015 08:56 PM
Old ford
Jul 31, 2015 06:50 AM
