WRC rear boot spoiler - Help needed
Old Jan 21, 2010 | 03:50 AM
Doyne's Avatar
Doyne
Default WRC rear boot spoiler - Help needed
Hi all,
Take it easy on me, I'm new to all this...
Bought a WRC rear spoiler on eBay, just wondering if anyone has experience in fitting these. presume it straightforward enough.
Its gonna go on a 2001 Focus
Any fitting instructions out there as mine is 2nd hand and none came with it.
Aprreciate the help.
Cheers,
Doyne
Old Jan 21, 2010 | 05:40 PM
I would make your self some templates of the mounting bolts first, then do some maths, to ensure it is dead centred etc, mark out the boot lid as will be hidden when once on anyway.
No hurry so take your time, check for aerial mast clearance, wiper arm clearance(if fitted).
When you start drilling use a centre punch, or nail to mark the centre, then progressively enlargen holes as needed.
Once all the holes are done, then file/remove all rough edges around holes, then apply anti rust compound, a few coats allowing to dry between each, then pain any old paint over this, spray paint into the lid and use small modelling brush.
When all dried put some sealant, such as Loctite 5900 or 5910 to both sides of hole edges, this will make doubly sure of no rust, also apply sealant to the legs/supports/sections of the spoiler where it attaches to the car, bolt down, allow 24 hrs to fully dry sealant, then simply pull the sealant it will come off neat as anything.
That's how I do it, to ensure a good fit with no rust in a few years, remember preperation is 90% of the job for a good job.
Post some piccies up once done!!
jessie_rs
11
Jun 3, 2019 04:57 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
col93saphcos
Aug 7, 2015 03:21 PM
