changing the gearbox oil on an RST easy job?
Old Jan 4, 2005 | 08:07 PM
Gra's Avatar
Gra
Default changing the gearbox oil on an RST easy job?
is it an easyish job to do as i wanna do it at the weekend but cant find my new bible (haynes manual)
Old Jan 4, 2005 | 08:19 PM
ballin's Avatar
ballin
dont think so, aint you gotta drill it ?
Old Jan 4, 2005 | 08:31 PM
sm's Avatar
sm
u have to drain it out through the drive shaft hole, to completely empty it its a gearbox out job
Old Jan 4, 2005 | 09:01 PM
Gra's Avatar
Gra
fook it it can wait then
Old Jan 4, 2005 | 09:10 PM
nigel b's Avatar
nigel b
jack the fooker up
disconnect antirollbar+remove tca from chassis
lever out driveshaft
you should have it done fairly quickly
Old Jan 4, 2005 | 09:25 PM
Ginge !'s Avatar
Ginge !
just finding my feet
longer driveshaft is easier to remove btw, then ya need a 8mil allen key and then fund the allenkey bol on the fron of the gearbox and refill , not too fast though !!!!, then wait 30 mins and fill some more ( as the 5th gear needs to fill up with oil )
Old Jan 4, 2005 | 09:26 PM
EIL132's Avatar
EIL132
As said above, pump the old fluid out
Old Jan 4, 2005 | 09:39 PM
Lee Reynolds's Avatar
Lee Reynolds
bear in mind youll need a small 'squirty' 1 litre bottle, then a large bottle of fluid. Ya fill it up using the small squirty one topping that up with the big one
Old Jan 4, 2005 | 09:42 PM
nigel b's Avatar
nigel b
or use a long tube+funnel
Old Jan 4, 2005 | 09:43 PM
essexrsturbo's Avatar
essexrsturbo
does it matter if you over fill?
Old Jan 4, 2005 | 09:45 PM
Lee Reynolds
if youve got a long tube and funnel
Old Jan 4, 2005 | 09:50 PM
nigel b's Avatar
nigel b
you cant overfill
i always fill it up jacked up-get slightly more oil in
Old Jan 4, 2005 | 09:51 PM
John Laverick's Avatar
John Laverick
You can't
Lee Reynolds
its supposed to be 10mm below the bottom of the allen key filler cap.
Old Jan 4, 2005 | 10:33 PM
rstdave's Avatar
rstdave
Me and a mate changed mine after the old one shat itself...and to be honest it turned out to be a bit of a job! Easy gettin it out...but gettin it back in's a bitch if u've only got axle stands!!
Old Jan 4, 2005 | 10:36 PM
Lee Reynolds
Didnt ya have a jack?
Changing the oil is a bitch???? Hope ya never have to change the clutch cable
Old Jan 4, 2005 | 10:39 PM
MikeyXR2i's Avatar
MikeyXR2i
Ive always found it quite easy to do, is a bit tricky filling up but its okay.
Old Jan 4, 2005 | 10:49 PM
rstdave's Avatar
rstdave
oops..read it wrong, thought u were on about changin the actual gearbox!!
Old Jan 4, 2005 | 10:58 PM
Lee Reynolds
lol no
Old Jan 5, 2005 | 01:00 AM
Hardeep_Singh's Avatar
Hardeep_Singh
messy job
Old Jan 5, 2005 | 06:44 AM
Gra's Avatar
Gra
cheers, driveshafts you say to my wife driveshafts are a swear word, due to when i sold my cossie shafts the guy who bought em got oil over his shoes, then walked over my wifes brand new cream carpet
sounds a bit tricky, but will give it a go, just watch out for the
"oh shit my gearbox fell apart post"
Old Jan 5, 2005 | 06:57 AM
Eagle's Avatar
Eagle
Super Moderator
get drill .. drill hole into lower casing slowly .. get all oily .. tap out a thread get bolt and refit .. refill with some oil .. allow to settle .. remove bolt .. get oily again .. all swarf etc should come out .. refill and off you go ..
well thats what i did and it worked ... the theory was that the ally swarf is alot softer than the large metal gears
just remember i aint no tecnical person
Old Jan 5, 2005 | 07:07 AM
zvhturbo's Avatar
zvhturbo
These boxes do have a drain plug.
Its a stud about 60mm long right at the front of the box, i think it sits in the middle of the front mounting bracket.
Remove it and lower the car back down and all the oil will drain out.
Re-fil using the filler plug that is directly above the drain plug.
Matt.
Old Jan 5, 2005 | 07:12 AM
flashpoint's Avatar
flashpoint
As Eagle, drilling a hole, is the only way to remove all the old
In this photo you can see the drain plug, ignore the oil!!!!!!!
Steve
Old Jan 5, 2005 | 07:47 AM
JesseT's Avatar
JesseT
That's no RST gearbox.
Old Jan 5, 2005 | 08:06 AM
flashpoint's Avatar
flashpoint
Old Jan 5, 2005 | 09:44 AM
nthorpey's Avatar
nthorpey
I have fitted drain plugs to all my gearboxes in the past which does make it extremely easy to empty the oil, i have actually welded a threaded boss onto the casing so that it retains the thickness. To get the oil back in i use a type of 'easy bleed' arrangement and a pumped up lorry tyre. this makes iit very easy and quick to fill
Old Jan 5, 2005 | 09:52 AM
essexrsturbo
wots all this drilling buisness? theres a drain plug on the S2 gearbox
Old Jan 5, 2005 | 09:58 AM
CabrioTurbo's Avatar
CabrioTurbo
yes there is a drain plug.. however i dont think ALL the oil drains out of the box with this undone.. never done mine any harm.. the box's dont last long enough to warrant an oil change anyway!
Old Jan 5, 2005 | 10:21 AM
keithG666's Avatar
keithG666
Old Jan 5, 2005 | 10:49 AM
Gra's Avatar
Gra
sod it lets just see if my box will last the beds regional day
Billy_RS
16
Oct 11, 2025 09:41 PM
Chas
Sep 21, 2015 08:57 PM
cameron2
Aug 25, 2015 07:18 AM
st220kyle
16
Aug 14, 2015 06:13 AM
dlwarrior
Aug 5, 2015 10:19 AM
