2.3 galaxy engine
hi all ive got the opportunity to get a 2.3 petrol galaxy engine on the cheap its the chain driven one think its an i4 iirc?
i was wondering if anyone has turbo'd one of these or even the 2.0 im thinking of doing this and putting it in my erst does any one know of low comp pistons and turbo spec cams or am i going to have to get my wallet out and get everything custom made?
cheers peeps
cheers peeps
cheers peeps
cheers peeps
Area Six (Ian Howell) 01522 877887, did one the block split on the dyno, but was at silly power when it did. I belive he may still have bits but be warned he spent an awfull lot of dollar on development so don't expect bargains.
Forged low comp JE pistons are available for the chain driven 2.3 I4 engine.
Sign on to WWW.RS2000-16v.com for all the info
Mark
I think you're confusing it with the 2.3 Duratec belt driven/mazda engine.
Mark
Mark
cheers peeps
cheers peeps
as in it will stick out the top a fair bit so you'll have to put in a bonnet bulge
2.3 is the same size as the 2.0 and you have to use a fillit peice to blank off teh oil feed in the block ot the balancer shafts, fairly simply but it's got to be done right
not too sure about engine moutns, but the rwd and fwd blocks have the same casting, just not tapped out for each application, so at least you are starting with the right version
scorpio's can be had for peanuts compared to galaxy's so if you want bits just get one
change the chain, the kit comes in at around Ł140 for everyting you'd need and the timing marks are copper linked on the timing chain so you can't get it wrong
hi dojj i had read about them being too high on other forums but there are ways around this without doing owt to the bonnet it just requires lowering the engine (made it sound easy lol) which i was going to do on my chv anyway to make it a bit easier to fit my mtx75 gearbox for clearance around the brake servo.
the engine will be getting dummy fitted before ive spent any money trying to turbo it anyway and if it doesnt look like its going to work its not a big loss as ive got it really cheap anyway and should be relativly easy to sell on
doing it to be different everyman and his dog have zetec turbo's (probably because they are ace) and cant be arsed with the cvh anymore they are passed their sell by date now and where never that good of an engine to start with
and dojj i would but got my cossy mk2 escort for sideways fun!
Mark
Mark
i'm guessing the galaxy is a 2.3 version of the rs2000 type lump then?
The Ford/Mazda I4 is chain driven also.
And yes the older type Galaxy 2.3 was based on the RS2000 16v motor which is based on the old 2 litre 8v DOHC Sierra engine.
I have no idea at all what the more modern Galaxys use for power plants ?
Mark
It is the duratec (mazda derived unit)
