Any Rover Mechs ?
Old Jan 16, 2010 | 03:46 PM
Shandy-Ade's Avatar
Shandy-Ade
Default Any Rover Mechs ?
My brother in laws Rover 75 has gone up the wall and wondered if anyone on here will know the problem.
Basically it's only a weekend car, serviced every year, today he went shopping came home parked up for about half hour, went to start it and nothing, he says the Inspection light is on the dash but the car just turns over.
Anyone any ideas?
Thanks
Old Jan 16, 2010 | 03:53 PM
rs2ksligo's Avatar
rs2ksligo
is it a diesel one
Old Jan 16, 2010 | 04:25 PM
Standard feature on some diesels, some have THREE fuel pumps, any one can pack up.
They also suffer a hole host of other problems.
My mate richard does nothing but rovers, so he might be able to help, 01953 458000
Old Jan 16, 2010 | 04:37 PM
london_chris's Avatar
london_chris
is it a v6 model????
i would be incline to disconnect and reconnect the camshaft sensor,
if a normal k series engine, disconnect the fuel inertia switch and crank, see if it fires?
let us know
Old Jan 16, 2010 | 04:46 PM
Shandy-Ade's Avatar
Shandy-Ade
Thanks for the replies, forgot to say it is a petrol.
London Chris, not sure what engine it is so willget him to check, will let you know
Old Jan 17, 2010 | 01:34 PM
Shandy-Ade's Avatar
Shandy-Ade
Turnt out the battery was fooked !
Old Jan 17, 2010 | 01:41 PM
utternutter's Avatar
utternutter
but you said it was turning over?
Old Jan 17, 2010 | 01:56 PM
RichieST's Avatar
RichieST
Can be the battery, a friend's clio would just turn over and not fire. Stick a set of jump leads on it and it would go first turn of the key. It was turnign over but just not quickly enough to get it to go. New battery and it was fine!
Old Jan 17, 2010 | 02:00 PM
Shandy-Ade's Avatar
Shandy-Ade
That's exactly what was happening, i jumped him from my car, went first time
Old Jan 17, 2010 | 06:38 PM
foreigneRS's Avatar
foreigneRS
Testing the future
a weak battery can seem like it's turning over if it's got an inertia starter motor, the motor turns but does not have enough speed to throw the gear onto the flywheel and turn the engine over
Old Jan 17, 2010 | 06:51 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Rover 75's won't turn over at all once the battery drops too low, the solenoid clicks repeatedly and the headlamps flash.
Old Jan 17, 2010 | 07:46 PM
Shandy-Ade's Avatar
Shandy-Ade
Strange as i was there yesterday, turnt over albeit a bit slow, but wouldn;t start, he put his multimeter on batt today and got a reading of just over 10v, so he asked if i would jump him, left jump leads on for 5 mins and she fired straight up
Vincereese
Ford Escort RS Cosworth
Nov 7, 2015 09:01 AM
AJC
Oct 1, 2015 06:47 PM
Vincereese
Sep 5, 2015 10:46 PM
cos elle
Sep 1, 2015 06:48 PM
Graceland
Jul 31, 2015 10:34 AM
