How to fit an oil pressure gauge?
Old Jan 16, 2010 | 01:19 PM
mattseries2's Avatar
mattseries2
Default How to fit an oil pressure gauge?
Having a bit of trouble guys...
Dont know what to go for a machanical one or and eletrical one?
And how do i fit them?
Old Jan 16, 2010 | 02:33 PM
nigel b's Avatar
nigel b
get the electrical one
replaces the existing oil pressure switch
Old Jan 16, 2010 | 02:38 PM
sir nose's Avatar
sir nose
get an electrical 1,you dont want hot oil entering the cab.i got a sandwich plate for the old sensor and added a temp sensor too while using the originaloil pressure hole in the engine block for the new gauge sensor.
Old Jan 16, 2010 | 06:08 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Electrical are more prone to inaccuracies (so i've heard) and respond much slower to changes in oil pressure....... I've had both BTW and now would only use mechanical
Yes you do run an oil line inside the car but as long as you fit it correctly you wont get any leaks! lol
RUBY123
Oct 22, 2023 12:04 PM
Chas
Sep 21, 2015 08:57 PM
mrmann
Aug 20, 2015 11:24 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
track.focus'd
Aug 12, 2015 05:53 PM
