Omex rev limiter
Old Jan 16, 2010 | 12:37 PM
mattseries2's Avatar
mattseries2
Default Omex rev limiter
Worth having one?
Old Jan 16, 2010 | 12:46 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
if you find yourself over reving a lot, then yes.
Old Jan 16, 2010 | 01:15 PM
mattseries2
I dont over rev alot its just for peice of mind so that i know wen i do put my foot down that i dont over rev it...I take it the omex ones are good?
Old Jan 16, 2010 | 01:28 PM
fiend's Avatar
fiend
Does MFi not have a rev limiter?
Old Jan 16, 2010 | 01:33 PM
mattseries2
Im not sure thats why i wondered if was worth fitting one
Old Jan 16, 2010 | 02:03 PM
Micky's Avatar
Micky
Yes.
Old Jan 16, 2010 | 02:44 PM
10th_racer's Avatar
10th_racer
i had 1 on my old efi zvh, never really over revved it but it was piece of mind incase you did get a bit carried away or dropped it into the wrong gear. That was on efi thoug and wired to the coilpack, im not sure if you can run 1 with a coil on mfi, i'd assume you could but not 100% sure.
Old Jan 16, 2010 | 08:30 PM
RS1HEN's Avatar
RS1HEN
got to be a rev limiter, otherwise some numpty would of sat on the forecourt and reved the death out of it
Old Jan 16, 2010 | 09:33 PM
jaiscossie's Avatar
jaiscossie
One for sale on the forum here mate
https://passionford.com/forum/non-fo...evlimiter.html
Old Jan 16, 2010 | 10:03 PM
Rob_DOHC's Avatar
Rob_DOHC
I was considering getting one for a while as with slightly worn mounts and gammy gear selector missing 3rd can be quite easy, omex are okay, they have a soft and hard rev limit which is nicer than the standard rev limit, not that i know as i think mine has had the rev limit removed!?!?!
Old Jan 18, 2010 | 02:27 PM
mattseries2
Cheers guys!
Do u know if it can be used with MFI?
Old Jan 18, 2010 | 06:12 PM
10th_racer's Avatar
10th_racer
mine sounded ace on the hard rev limit, used to pop and bang like a bastard lol.
Old Jan 18, 2010 | 06:29 PM
jammerrs's Avatar
jammerrs
what is a hard and soft cut limiter?
Old Jan 18, 2010 | 06:39 PM
mattseries2
Was yours fitted on MFI?
Old Jan 18, 2010 | 07:53 PM
Rob_DOHC's Avatar
Rob_DOHC
ye you can fit them on mfi, they cut the coil. A soft limit feels like a missfire and the engine goes a bit feathery, designed to limit nicely when accelerating normally upto the limiter in gear, a hard rev limit sounds more like a stardard bongbongbong limit, this is more for a very fast rev up ie when a gear is missed or wheels spin, this hard limits to reduce the maximum engine speed which could occur when a wheel with momentum spins for example, or the engine is revved hard out of gear, the momentum of the wheel or flywheel can actually throw the rpm past a rev limit, thefore a soft limit leading into a hard limit is used to minimise this and reduce shock loadings that would otherwise be caused by a nasty limiter on its own.
does that make sense? got a cracking head ache lol
Old Jan 18, 2010 | 08:35 PM
mattseries2
Haha...yeh it does make sence Rob cheers for that, think i mite invest, just incase i do miss a gear!
SMILER258
Sep 28, 2015 09:04 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
dombanks
Sep 21, 2015 08:38 PM
Tank Mike
Sep 14, 2015 03:56 PM
