focus problem
Old Jan 16, 2010 | 12:34 PM
delterflier's Avatar
delterflier
Default focus problem
hi all
last night my 03 plate 1.8 16v focus started kangerooing like a bitch on low revs,its done it once or twice before but now its bad lol
ive changed the plugs and leads not so long back,when i serviced her.
just wandered if the coil pack on my 1.8 xr2i would work/fit.
wanted to try that to se if its the problem before goin out and buying a new one.
cherrs john
Old Jan 16, 2010 | 12:42 PM
utternutter's Avatar
utternutter
you can plug the coil pack in to test but it wont mount properly, i done the same recently used a coil pack off an old m reg escort lol
Old Jan 16, 2010 | 12:56 PM
delterflier
did u find that was the problem?
how much do coil packs go for?
cherrs john
Old Jan 16, 2010 | 12:58 PM
utternutter
well if you can plug one in to test it will cost you nout and eliminate that possiblility, then i would be looking for air leaks etc a spray about with carb cleaner etc will reveal any
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Could be air flow meter mate or idle speed control valve perhaps, Do these have egr valves??
Old Jan 16, 2010 | 01:04 PM
as355f1's Avatar
as355f1
unplug the airmass meter and try it
Old Jan 16, 2010 | 01:09 PM
delterflier
what do thay all plug into ?
soz having a bad day lol
Old Jan 16, 2010 | 01:13 PM
as355f1's Avatar
as355f1
between the air box and the throttle body there is a plastic tube with a multi plug on it, unplug that and see if the problem goes
Old Jan 16, 2010 | 01:16 PM
delterflier
ok cool will go check
Old Jan 16, 2010 | 07:54 PM
delterflier
ok checked the air mass meter,was clean.sprayed a bit of carb cleaner throw it anyways.
then checked my plugs and leads.....
found oine plug loose but cleaned them all up put them back in propley
started her and she seamed fine ....till she warmed up
so went and got redex put that in and ten miles later she seams ok
cherrs for the help
john
Old Feb 20, 2010 | 11:56 AM
delterflier
ok still got problems
bought a mass air flow meter today so far so good but have found it hesitates more when fully warmed up so am working tonight ,time will tell
john
Old Feb 20, 2010 | 04:13 PM
kosman's Avatar
kosman
sideways all the way!
change down a gear
Old Feb 20, 2010 | 07:20 PM
martysmartie's Avatar
martysmartie
When was last time fuel filter was changed??
Martin
Old Feb 21, 2010 | 01:27 AM
delterflier
Originally Posted by kosman
change down a gear
Old Feb 21, 2010 | 01:29 AM
delterflier
change down a gear
Martin
was only changed bout 6 month ago
Old Feb 21, 2010 | 09:03 AM
studabear's Avatar
studabear
If it runs crap warm, I suggest replace the cts (coolant temp sender)
Old Feb 21, 2010 | 11:50 AM
delterflier
where is that on the engine?
ive realy gota get a manual lol
Old Feb 22, 2010 | 10:17 PM
martysmartie
They don't have a conventional CTS, its a CHT (Cylinder Head temperature) sensor and measures the temp of metal diectly and works on a NTC principle. it's on cam cover between plugs 2 and 3, if you pull this lead and turn ignition on fans should run and should EML should illuminate due to a fault being registered, when plugged back in it should rectify this if working correctly, it also controls temp gauge so if you have an abnormal reading this could be an indication.
Martin
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
jaysoc1
Aug 20, 2015 08:18 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
taylora1409
Aug 12, 2015 12:06 PM
