Finally the Escos is fixed!!- Warning- Don't use Burton Power oil pumps!!
Old Jan 15, 2010 | 02:33 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Default Finally the Escos is fixed!!- Warning- Don't use Burton Power oil pumps!!
Well, after months of problems with the Escort Cossies oil pressure following a brand new engine build, it seems that the brand new Burton Power oil pump was the culprit ...Being a small turbo, the oil pump has no spray bar, and is a very basic design that is identical to a pinto one.
Got the oil pump replaced yesterday with a new one from another company, and immediatly it fixed the crap oil pressure on start up, and non-existant pressure when the car warmed up. It seems that the machining on the releif valve is very very poor, and allowed the valve to stick open, causing oil pressure to drop off as soon as the car warmed up ..
To say I am not happy is an understatement, I will be getting the pump inspected by an independant 3rd party, and will be approaching Burton for the cost of a new pump and the labour to replace it ...
But in the meantime, at least I now have an Escort Cosworth that I can use again , made me very happy today when it fired up and ran perfectly ..
Old Jan 15, 2010 | 02:38 PM
ECOS95's Avatar
ECOS95
What was wrong with the original pump? Hope the low oil pressure hasn't damaged the engine . I'd be looking for some compensation from Burton.
Old Jan 15, 2010 | 02:41 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Great news its fixed
I hope Burtons do the decent thing for you
Steve
Old Jan 15, 2010 | 02:46 PM
RWD_cossie_wil
Shells and bores were inspected, they are perfect. The oil pressure was fine as long as the engine had some revs on, just from cold took 6-7 secs to build pressure, and at idle the pressure would drop off.. The engine was harldy used due to the issue, so it has not suffered at all thank god, as it is a fresh build and still running in, just glad I have got it sorted.
Still think it's very bad form to sell a crap oil pump though, they must have tested them?
The original pump had done 110,000 miles, and was pretty much perfect and would have gone again happily, but due to it being a total rebuild for big power, it made sense to stick a brand new high flow 5 bar pump in with the build.
Old Jan 15, 2010 | 02:57 PM
ECOS95's Avatar
ECOS95
Its shocking to think that such a relatively cheap part can cause so much aggro.
Old Jan 15, 2010 | 02:59 PM
SteveB's Avatar
SteveB
Oh dear I have a ST high pressure pump in mine....lol
Old Jan 15, 2010 | 03:01 PM
COCHYN's Avatar
COCHYN
What's wrong with using a genuine Cosworth pump?
Old Jan 15, 2010 | 03:37 PM
RWD_cossie_wil
Not available anymore for a small turbo mate, I looked everwhere for one, and I mean everywhere
Old Jan 15, 2010 | 03:56 PM
T3ORA's Avatar
T3ORA
fuck me will
you have pulled your finger out you arse and changed the pump about time
so will the escort see the road this year under its own stream and not a tow rope
Old Jan 15, 2010 | 03:58 PM
RWD_cossie_wil
Originally Posted by T3ORA
fuck me will
cock
Old Jan 15, 2010 | 04:02 PM
cossiejsy's Avatar
cossiejsy
well done mate but not a good advert on burton's behalf
Old Jan 15, 2010 | 04:15 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
blimey. glad i didn't buy a burton pump when i rebuilt mine. glad you have got it sorted, matey. hope they sort you out with cash for your troubles
Old Jan 15, 2010 | 04:19 PM
fezzajsy's Avatar
fezzajsy
Old Jan 15, 2010 | 04:22 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Good news that its running and suffered no damage!
Old Jan 15, 2010 | 04:28 PM
LHD220Turbo's Avatar
LHD220Turbo
not the first timed i've heard of dodgy burton oil pumps
good news Wil
Old Jan 15, 2010 | 04:41 PM
GUZZLER's Avatar
GUZZLER
i had the same with a pump from someone else......
Old Jan 15, 2010 | 04:42 PM
T3ORA's Avatar
T3ORA
Originally Posted by RWD_cossie_wil
cock
Old Jan 15, 2010 | 05:12 PM
MarkN's Avatar
MarkN
Great news
So when will you be taking the car down to MSD to complete the new small turbo tuning package? Can't wait...
Thinking about it - I seem to remember a thread a while back about other people having major problems with YB oil pumps from Burtons...
Old Jan 15, 2010 | 05:19 PM
Ben26's Avatar
Ben26
how did u know the oil pressure was low ?
Old Jan 15, 2010 | 05:51 PM
MarkN's Avatar
MarkN
The oil pressure gauge in the banana pod at a guess.
Old Jan 15, 2010 | 05:52 PM
glad you have got it fixed well done.
Old Jan 15, 2010 | 06:33 PM
Ian M500COS's Avatar
Ian M500COS
Does that mean you know longer want a Porsche 996 Turbo Wil? Glad you've sorted it tho!
I doubt Burtons will pay anything though, you may get a replacement pump out of them but I think that'll be pushing it.
You still dropping down to mine for tea next week mate?
Old Jan 15, 2010 | 06:57 PM
RWD_cossie_wil
Still fancy a porsche, but will see how the Escort goes for a bit! Will have to be week after next for a drink as I'm on nights next week.
Hopefully go to MSD soon, got some niggles to correct but are only details! Got to go to adrenaline to fit my frame connectors, and pro-alloy for an intercooler which will cover most of the running in miles as well!
Old Jan 15, 2010 | 11:10 PM
tomoyb's Avatar
tomoyb
what sort of pressure were you getting from cold on idle,warm idle and 3-3.5k revs in 5th?
thanks as i have one of these pumps in mine
Old Jan 15, 2010 | 11:15 PM
GUZZLER's Avatar
GUZZLER
i thought mine was ssuspect, engine sounded great, but if you left it on idle for a few mins then lifters would get noisey
Old Jan 16, 2010 | 12:08 AM
RWD_cossie_wil
Starting from cold it took 5-7 secs to build enough pressure to turn the oil light out, then it hit over 5 bar as it should do. You could watch the pressure drop as the engine warmed up, and eventually at idle the pressure would drop off the end of the in car gauge scale, and the followers would rattle.
As soon as you revved it, the pressure shot up, but you had to hold revs for the followers to quiet down. With the new pump, pressure is instant from cold, and it does not drop below about 1.5-2 bar at hot idle. Engine is sweet as a nut with no noise at all now.
big_Rad
Sep 15, 2017 09:36 AM
SteveyDee
Aug 24, 2015 05:43 AM
Dubs44
Aug 21, 2015 02:42 PM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
