wen do u no its time for a set up ?
Old Jan 14, 2010 | 08:28 PM
dale rs1989's Avatar
dale rs1989
Default wen do u no its time for a set up ?
wen do u no its time for a set up ?? wat do they do and how much are they ???
Old Jan 14, 2010 | 09:38 PM
orionmojo's Avatar
orionmojo
If you've just bought an rs its always a good idea to get it set up. Other than that whenever you fit a performance part, one to make sure you dont melt anything, two to make sure you get the most out of it. I get mine done once a year anyway. its expensive but i've always got more parts to fit at the same time, so plan it for then
Theres loads of decent places to get an RS tuned, dont give it to any old monkey at a kwik fit though, find a specialist through the website and give them a call.
Old Jan 14, 2010 | 09:42 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
£141 from us.
id say once a year is an ideal for a setup
Old Jan 14, 2010 | 10:42 PM
mattseries2's Avatar
mattseries2
Yeh what Mojo said, dont take it to someone that dont know what they doin! Go to a specialist!
Old Jan 15, 2010 | 09:54 AM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
Take it to james at woodford garage m8 as its also near to you, thats where i get mine done its around £50-70+vat to sort fuelling and check boost etc
Old Jan 15, 2010 | 10:53 AM
KSA-Cossie's Avatar
KSA-Cossie
i get the saph done once a year
Old Jan 15, 2010 | 12:02 PM
1223456's Avatar
1223456
My S2 was popping all the time, took it to MSD and will sorted it
The setup seemed to fade a tade after 4 months but this was due to the crappy MFI which is always going to determine how often it gets setup
Old Jan 15, 2010 | 07:11 PM
ROB7656's Avatar
ROB7656
also get mine done once a year wich is about 6k miles at most. better to be safe than sorry with a rs turbo imo.
Old Jan 15, 2010 | 07:57 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah most metering heads drift out of 'calibration' quite quickly so a regular setup is essential now they are 20+ years old!
FlashRS
Aug 30, 2015 08:07 PM
Steve Escos
Aug 24, 2015 07:56 AM
sjssms
Aug 2, 2015 07:01 PM
