ARGGGHHH!! BROKEN DOWN!!!!!!
Old Jan 4, 2005 | 01:20 PM
Cawood's Avatar
Cawood
Default ARGGGHHH!! BROKEN DOWN!!!!!!
Well Happy New Year lads, i've had a great start to 2005.
first day back at work this morning, on my way down, get halfway then all of a sudden the revs died, tried dropping it down a gear to find the same.
car had died, pulled to a stop and tried starting it again, turns over ok but doesn't fire up?!?!?
this happened about a week ago, cut out on me but after about 5min managed to get it started again.
i get the feeling its being starved of fuel, plus yesterday i did nearly run it empty.
any idea's?????
oh by the way this is my XR3i not the RST
dave
Old Jan 4, 2005 | 01:22 PM
A.Moore's Avatar
A.Moore
Possibily a dodgy fuel pump/and or connection?
Old Jan 4, 2005 | 01:35 PM
Cawood's Avatar
Cawood
cheers moore, does it sound fuel related to you?
Old Jan 4, 2005 | 01:37 PM
A.Moore's Avatar
A.Moore
If it has anything to do with running the fuel low, try changing the fuel filter too!
Old Jan 4, 2005 | 01:38 PM
xr4x4rs's Avatar
xr4x4rs
check you fuel pump relay
does sound like fuel problems
check fo rspark as well dizzy or that stupid sensor on top of the dizzy
good luk mate
Old Jan 4, 2005 | 01:41 PM
A.Moore's Avatar
A.Moore
good luk mate
yep a very common problem on them.It's the purple relay under the drivers side dash.
Cawood's Avatar
Cawood
thanks lads
i'll check them things out, need to get this sorted ASAP as i need A car!!! RIP RS now RIP XR as well
what and wheres the fuel pump relay?!?!?
Old Jan 4, 2005 | 01:49 PM
CabrioTurbo's Avatar
CabrioTurbo
yea deffo sounds like fuel pump relay my old cab used to do it.. i didnt have a clue what was wrong until i called the AA out one day as it wouldnt re-start... he knew straight away what it was!
the fuel pump relay as above is a BIG puple one somewhere under the drivers side dash.. its probably melted!
Old Jan 4, 2005 | 02:24 PM
Cawood's Avatar
Cawood
bugger, how do i find it?
Old Jan 4, 2005 | 02:34 PM
xr4x4rs's Avatar
xr4x4rs
look under your dash board drivers side and you should feel or see a load of relays
theres a tag at the back of the hold push in and push up then you will see the relay
as said its the pink one
just replace that first cheapest and easiest
then check fuel pump priming if not check wiring on pump or replace pump
change filter aswell as said before
Old Jan 4, 2005 | 02:53 PM
rabmc's Avatar
rabmc
Stupid question m8 , but this happened to me twice now , did not have any fuel in it , guage reading dodgy , just a thought , sometimes the most obvious is overlooked
Old Jan 4, 2005 | 03:04 PM
CabrioTurbo
my mate used to have to 'shake' his nova to see if there was any fuel left in it!
Old Jan 5, 2005 | 11:08 AM
Cawood's Avatar
Cawood
shut up rab! lol course I have
Old Jan 5, 2005 | 12:17 PM
Chipperx2's Avatar
Chipperx2
I know this is silly,, but check part of yer loom hasn't sagged down and is resting against the rocker cover or any hot area and has melted the wire covers, thuus shorting wires, especially to teh fuel pump. This happened to me, took me weeks to figure it out
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
mjonathan24
Oct 29, 2015 10:39 PM
155lee
Oct 24, 2015 11:11 AM
