RS1800 Throttle bodied
Hello,
I have a RS1800 fiesta.
it has the usual exhaust, manifold, induction kit, cams and chip etc.
the car is my track car and I now want a bit more power, I do not want to go down the turbo route, I have a skyline for that.
I want throttle bodies, I have been doing research and I can get Omex management for £550 comes with water and oil temp sensors etc.
The best quote so far for direct to head throttle bodies is £690 (Jenvey)
I'm probably looking at £500 to have the Omex mapped.
So it's looking around £1800 all in.
Are there any better deals for direct to head throttle bodies out there?
I will eventually go for a straight cut gearbox etc but the gearbox is fine at the moment.
When the engine goes pop I will have the head rebuilt with larger valves etc to try and get around the 200bhp mark.
The car is approx 150bhp so I would expect to see in the 170's (bhp) with throttle bodies.
Thanks
Rob
Thanks
Rob
https://passionford.com/forum/trader...nd-mapped.html
matts doing a proper deal here.as you have cams you should see 170bhp
jenvey dont do direct to head for zetec they use a new inlet manifold.
get yourself a rs turbo diff in your gearbox because it will just spin passengers wheel without it
Doug
Doug
mk3ste
Oct 17, 2021 10:09 AM
