grs intercooler on s1's
Old Jan 9, 2010 | 07:07 PM
c123s1turbo's Avatar
c123s1turbo
Default grs intercooler on s1's
hi all im looking to fit a front mount to my s1, but idealy dont want to be cutting my front panel.
i heard that grs coolers fit without cutting, is that correct?
does anyone know of any others that are good that fit without cutting.
cheers
Old Jan 9, 2010 | 09:11 PM
morph's Avatar
morph
it depends on the fan your gonna use but you will need to bend the panel outwards.
Old Jan 9, 2010 | 09:26 PM
JesseT's Avatar
JesseT
This is a picture of my old -85 Orion. Some cutting will be needed, unless you can fit the fan behind the rad like in an XR3i. This won't work at least with the standard turbo manifold. With a single fan, the cutting will be minimal. With two, the mask lower mounting points sadly need to go. Even with two fans, the radiator will be struggling and the car needs to stay on the move. It will overheat easily if left idling. It's a very effective intercooler, but completely blocks the radiator. I don't know what better to recommend, but it's not for a daily driver.
The front panel in the picture is also bent forward, not just trimmed.
Because the lower mask mounts are gone, it's fixed with three screws from the top. You can see the holes for them.
Old Jan 10, 2010 | 12:42 PM
c123s1turbo
anyone running a airtec one like the ones sold by autospecialists?
Old Jan 11, 2010 | 06:31 PM
c123s1turbo
if i was to fit a front mount to a car running standard boost would it make it really laggy? cheers
Old Jan 12, 2010 | 07:06 PM
stwibs's Avatar
stwibs
nope
well mine wasnt !
i also ran mine with 1 x10 inch fan for 2 years just have to keep an eye on the guage and switch heaters on full when it starts to rise too much to be on safe side,but am going over to twin fans this winter ,
you can also fit a fan switch off a cossie and a lower temperature opening thermostat to keep temps down.
one other thing though mate ,i think you might struggle to get polished/shiny fans to match in with your bling !!!!
Old Jan 12, 2010 | 08:54 PM
c123s1turbo
cheers for your detailed reply mate! il have ago at chrome plating plastic mate lol
Old Jan 16, 2010 | 06:58 AM
S1 Combi's Avatar
S1 Combi
Im running the airtech front mount and alloy rad on mine,it says in the instructions that you only need to trim the front panel a little,as you can see i just went all out and cut the whole thing out works perfectly though,no issues with overheating or anything
Old Jan 17, 2010 | 07:12 AM
stwibs's Avatar
stwibs
show us a few more pics combi im thinkin of cutting the top section of front panel out too.can you see it from front? and have you left just enough for grill to sit on?
cheers
and are they 9 or 10 inch fans?
Old Jan 17, 2010 | 07:56 AM
gus's Avatar
gus
*****off topic*****
dude i love your combi, looks the nuts
*****back on topic*****
Old Jan 17, 2010 | 03:07 PM
S1 Combi's Avatar
S1 Combi
This is how the car looks at the mo because i havnt fitted a grille yet
Auto specialist supply you with a couple of bolts to put through the top mounts of the grille because they say you have to cut the bottom lugs off the grille,this is mine with the modified grille that we cut out
not sure of size of fans but will check and let you know mate
Old Jan 17, 2010 | 03:42 PM
c123s1turbo
superb mate thats for you pics, van looks the nuts too!
Old Jan 17, 2010 | 05:45 PM
stwibs's Avatar
stwibs
cheers combi,you cant tell once grills fitted that its been chopped out.
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
