this is wot u call a good answer!
Old Jan 3, 2005 | 09:29 PM
sufsRS's Avatar
sufsRS
Default this is wot u call a good answer!
dnt knw if ne 1 recalls me starting a topic on sparkplugs evn tho u guys were tryin 2 help sum of u were chattin crap nw this is wot u call an answer thnx to "white cab"
The center electrode is fine wire platinum for better starts, superior acceleration and better fuel econom. This plug is basically an efficient plug.
Iridium plugs , the latest evolution of spark plug technology. The iridium center electrode is both stronger and harder than platinum. This allows NGK engineers to design an ultra-fine (0.6mm)center electrode reducing the voltage requirement for spark. This allows for a brighter, stronger spark from your existing ignition system. The ground electrode has a tapered cut at the firing end which reduces quenching for better flame core growth and increased ignitability. The combination of fine wire center electrode and tapered cut ground will increase performance, improve acceleration, and fuel efficiency
found it in a search so iridium is best
so irdium all the way!!!
markk
Dec 2, 2021 06:59 PM
MadsBL
Wheels and Tyres
Aug 6, 2015 10:04 AM
COLEYST200
Aug 3, 2015 08:55 AM
