Has anyone put......
Old Jan 2, 2010 | 04:07 PM
Ben26's Avatar
Ben26
Default Has anyone put......
power steering onto there mk3 ?
if so how much did it cost for parts ?
Ben
Old Jan 2, 2010 | 04:16 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
my missus has a n reg Frescati, that has pas from factory. maybe find one of them and rob it?
Old Jan 2, 2010 | 04:38 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
Ben
YEA................. ford lol
my mk3 fiesta si had power stearing if you want it on your mk3 rs then you need the rack from an si and the pump and bracket set up from a mk6 escort cvh make sure you get all the pullyes en that you have to use the escort rs turbo exaust manifold set up as the t2 gets in the way as ive found
Old Jan 2, 2010 | 05:06 PM
graham c's Avatar
graham c
corsa power steering ? peace of piss ?
Old Jan 2, 2010 | 05:50 PM
Ben26's Avatar
Ben26
I find it very hard to get a straight answer off this site these days , everyone wants to be the site joker.
Old Jan 2, 2010 | 09:06 PM
bezo's Avatar
bezo
powered by K26
Ben
RS1800s run PS. but it such a small light car you really dont need it.
Old Jan 2, 2010 | 09:24 PM
crazycage's Avatar
crazycage
i could do with it on my fezz tbh ,with a 2.0 zetec and a big mtx box and 215/50/15 R888s its really heavy. i will be fitting the corsa b done it on a escort last year.
Old Jan 3, 2010 | 08:07 AM
1223456's Avatar
1223456
you will be doing mine as well while you are at it
Old Jan 3, 2010 | 08:55 AM
graham c's Avatar
graham c
it is a pretty much easy fit i have it on my mk1 4x4 escort
Old Mar 4, 2010 | 02:59 PM
DanFraser's Avatar
DanFraser
Go to a local scrappy and find a mk3 with the same engine and with power steering. You need tge steering rack, steering column, the pump which is below the alternator, the bracket holding on said alternator and pump. The fluid bottle and all connecting pipes. Simply take all of this and fit to yours. I say simply, it's a lot of work. I would strongly suggest a haynes manual.
Old Mar 6, 2010 | 12:40 PM
charlieboy's Avatar
charlieboy
i prefered mine without when i had my rst could feel how it was behaving better on the road.
Old Mar 6, 2010 | 12:51 PM
andy130's Avatar
andy130
tbh i think its very light on mk3s depends on wha engine you got mate, get your self on fiestaturbo.com mate
